6 to 5 lug conversion
When changing a '69 to 5 lug is it necessary to change the cross member, or can the '72 control arms be used on the '69 crossmember??
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
sharp as a marble
![]() Join Date: Jan 2007
Re: 6 to 5 lug conversion
69-70 spindles are different from 71-72. If you are converting to disc brakes, it would be easier to buy spindles for your truck. the 71-72 balljoints and tie rods are different
Yes, the 72 control arms will work on the 69 xmember
1997 GMC Sierra Ext 1965 Mustang |
member #16
![]() Join Date: Dec 1999
If you use a 71-72 center link you won't have any tie rod issues. That is assuming you have the 72 spindles and ball joints already.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
