12-14-2008, 06:22 PM | #1 |
6 to 5 lug swap
I have a '69 chasis that I am swapping the 6 lug with a '72 disc brake 5 lug set up. Is it necessary to swap the cross member, or will the '72 control arns fit the '69 crossmember??
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
12-14-2008, 06:27 PM | #2 |
Resident of Here
Re: 6 to 5 lug swap
I think they will git, dont quote me on that though.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
12-14-2008, 06:35 PM | #3 |
Re: 6 to 5 lug swap
Yes,swap the spindles and steering linkage along with it!
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
12-14-2008, 07:01 PM | #4 |
Re: 6 to 5 lug swap
thanks I'll do that, saves me a lot of work
12-14-2008, 07:03 PM | #5 |
Dave's not here, man
Re: 6 to 5 lug swap
I'm quite certain you can swap the arms to the existing crossmember. Then just swap the draglink, tie-rods, etc. and you'll be good to go.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
12-15-2008, 01:21 AM | #6 |
Re: 6 to 5 lug swap
if you dont have a motor in the truck just change the whole thing.... it should bolt right in.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
12-15-2008, 08:54 AM | #7 |
Under Construction
Re: 6 to 5 lug swap
if no motor, i would swap the whole cross member, not much more work. if you dont , you will have to drill the xmember to run and bolt the brake lines down as they run different.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-15-2008, 11:45 AM | #8 |
Re: 6 to 5 lug swap
WellI guess I just swap the whole thing, both chassis are engineless. Thanks for the help.
12-15-2008, 12:21 PM | #9 |
Under Construction
Re: 6 to 5 lug swap
