Old 12-14-2008, 06:58 PM   #1
harlyworkr
harlyworkr's Avatar
Painting help needed please
First of all let me start by saying "I am a Moron"
I need help understanding what went wrong. I painted my fenders and doors yesterday and when I went back to the shop to look at them I noticed Lines in the blue where it was not covered enough. (darn Lighting) I scuffer the clear and proceeded to the blue over it. It bubbled the paint like someone just threw on paint stripper.
Problem 2: When I realized it was a total loss I peeled the tape off and the clear peeled off in sheets with the clear. Where did I go wrong?
harlyworkr is offline   Reply With Quote
Old 12-14-2008, 07:14 PM   #2
Ram-Man
Ram-Man's Avatar
Re: Painting help needed please
Your color lifted the clear coat. Solvents were trapped and they had to get out. This can even happen with spray paint in a can. That is why alot of cans will say you can recoat within 1 hour or wait 48 hours to recoat. After 48 hours most of the solvents have left.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 12-14-2008, 07:14 PM   #3
JimKshortstep4x4
It sounds like the clear was not cured fully so the reducer in the blue paint attacked it. You may want to call your paint supplier.
I found out this past summer that the drying time given on the primer I was using was based on 100 degrees F and I was painting at 70 degrees F. Instead of 4 hours @ 100, (which I did not know about), I needed 32 hours @ 70).
Murphy and his laws move right in when you are painting as there seems to be thousands of things to go wrong!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-14-2008, 08:42 PM   #4
Painter D
Painter D's Avatar
The above post are correct. Sometimes when you have to repaint over fresh paint ,if you put it on too wet it will wrinkle like what you described. Wait for a couple of more days re-sand and try again. The reason you can see through the blue is probably because you didn't put enough coats of base on to cover it thoroughly. Don't get too frustrated painting can go south on you real quick sometimes for reasons that are totally out of your control. The last time I added it up I've painted somewhere in the neighborhood of 7000 cars, and every once in a while I get one that wrinkles up on me too. GOOD LUCK.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 12-14-2008, 08:49 PM   #5
cdowns
cdowns's Avatar
weather a rattlecan or stir and mix it really pays to read the instructions
Old 12-14-2008, 09:23 PM   #6
harlyworkr
harlyworkr's Avatar
Thanx everyone, all I need now are some tips. Anyone care to share some?
Old 12-14-2008, 09:37 PM   #7
msgross
msgross's Avatar
don't pee into the wind and never eat yellow snow!
just kidding..
I am learning this process too...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-14-2008, 11:10 PM   #8
Premium72
Premium72's Avatar
yeah you didnt wait long enough.
tips..
CLEAN CLEAN CLEAN.. when your done take your gun apart clean everything that paint touches and then clean it again.
keep your gun pointed at the panel your painting, dont "fade" it out on the edges. spray all the way past it, helps get an even coat.
Practice!. paint some ****. dont just start on your pride and joy. get some old bike paarts, a mail box, a rock, the cat. what ever. youve already learnd you gota let your primer paint and clear cure long enough before doing anything with it. youll learn alot playn with spray'n good luck.
Premium72 is offline   Reply With Quote
Old 12-14-2008, 11:37 PM   #9
El Jay
Gone to greener pastures
just kidding..
And never fry bacon when you are nude.
But that has nothing to do with painting.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 12-15-2008, 12:05 AM   #10
harlyworkr
harlyworkr's Avatar
I am going to use this one a lot.
Can you re-paint over clear?
If so, do you have to re-primer first?
Old 12-15-2008, 12:38 AM   #11
FIVE 0
Yes you can repaint over clear. You do not need to re prime. Main thing at this time is what 69chevyshort said. wait a couple more days then sand and redo. 69chevyshort is a def pro and should follow his advise for sure.
A couple things I would do is sand now with 400 wet and wait a couple days then spray. Reason is, it will give solvents a better chance to evap prior to re spray.
A trick to spraying metalics is to "set the metalics" I spray a coat going back and forth, go to the next panel and do the same. Then go back to the first panel and do a diagnal light coat or drop coat using mostly your wrist not doing a complete coat, just a dusting. This will set the metalics and give you a better chance at not having tiger stripes.
Hope this makes sense, easier to do then wright.
BTW what materials are you using?
FIVE 0 is offline   Reply With Quote
Old 01-16-2009, 01:34 AM   #12
sinned4me
You need to monitor you temperatures. Not just the room. Check panel temp, room temp, and material temp. I am an auto refinish supplier and a cold fender will do some odd things.
sinned4me is offline   Reply With Quote
Old 01-16-2009, 03:29 AM   #13
Wreckless_71
Wreckless_71's Avatar
"Well they say you're not supposed to eat after 5, but they also say not to drink in the morning... and you're never supposed to smoke crack." Lol, Jim Gafigan quote.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 01-16-2009, 03:46 AM   #14
thirdstreettito
Resident of Here
thirdstreettito's Avatar
The same thing happened when I painted my uncles truck, it was late and dew set on the paint, it trapped the solvents and we had a half flat, half gloss truck.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-16-2009, 06:16 AM   #15
RustyParts
RustyParts's Avatar
Holding the spray gun to close to the surface will cause striping also.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
