Old 12-14-2008, 09:31 PM   #1
Oregoon
Roadside Rebuilder
Oregoon's Avatar
'71 1/2 ton 5-lug rear end?
This is a direct bolt-in to a '66 Burb, right?
Oregoon is offline   Reply With Quote
Old 12-14-2008, 09:32 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: '71 1/2 ton 5-lug rear end?
Yeah, except the former 6-lug wheels........ Mine has one under it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-15-2008, 08:55 PM   #3
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Anything I should know while I'm pulling it from under said '71 tomorrow?
Old 12-15-2008, 10:14 PM   #4
protrash64
protrash64's Avatar
Smile Re: '71 1/2 ton 5-lug rear end?
I dont think so......maybe take the hardware in case you get some parts giving you a hard time or breaking; you know the story!!! As far as Im aware they are the same with a slightly wider track. You will need new wheels anyway. Have fun wrestling that thing around; dont blow an 'O' ring!!
Old 12-16-2008, 08:33 PM   #5
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Rear end is here! I went and pulled it (thank heavens for blow torches!), and it's now sequestered in my basement, atop a pair of jack stands. I didn't blow my O-ring either, though it was certainly strained beyond factory reccomendations.
I pulled off the *****in' chrome diff cover the PO installed (which I'll be losing) and counted 14 teeth on the pinion, and 43 on the ring gear, which pencils out to 3.071428571...and a bunch of other essentially useless digits.
Hell yeah 3.07 gears! Highway speeds here I come!
And it came with new shoes, wheel cylinders, and drums, too.
Not bad for $150.
Old 12-16-2008, 11:29 PM   #6
TimE
Hey Y'all!!
TimE's Avatar
Nice score. I'm sure it came out relatively well with a torch, otherwise...you might still be out there on your back trying to get it out. Good job!
TimE is offline   Reply With Quote
Old 12-17-2008, 12:25 AM   #7
protrash64
protrash64's Avatar
Cool man!
Old 12-17-2008, 07:29 PM   #8
SIR
SIR
SIR's Avatar
..you might think about getting the front end off of it for a complete change over....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 12-17-2008, 07:45 PM   #9
Oregoon
Roadside Rebuilder
Oregoon's Avatar
I thought about that, but I've already got dropped spindles, and I want to use the later style control arms.
That said, I'm heading over to look at upper and lower control arms, rotors, and calipers off a '77 tomorrow.
Guy wants $125, and says they're in great shape, with a bunch of new parts... We'll see.
Old 12-18-2008, 09:56 PM   #10
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Jeez! Good craigslist deals for me this week.
Got the whole front end, from spindle to spindle complete, with steering linkage, shocks, etc for $125.
It has aftermarket lifted springs in it though, which I'll be losing. Other than that, it's in great shape.
Not going to use the entire cross member though. Gotta totally disassemble it,clean, paint, etc, and of course, reassemble with my dropped spindles.
$375 out of pocket so far, and I have a five-lug rear end, dropped spindles, and most of my frontend hardware.
Now I just need a master cylinder, proportioning valve, brake lines, bushings, u bolts, wheels, tires, tie rod kit, shocks...
