Old 12-14-2008, 10:25 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Be Sure And Check Your Fuel Sending Unit
I'm working on the '70 4x4 and I started out by rebuilding the Carb., taking out all of the plugs, loading up the cylinders with PB Blaster, and after letting it set for a while give them all a shot of oil. I also wanted to drain the fuel tank and start off with all fresh fuel. As you can see in the first picture the tank is in excellent shape. I decided to pull the sending unit/pickup tube assembly out to siphon the gas out and I'm glad I did. The next three pictures are what I found. The float arm is stuck as well as the other obvious problems.... Moral of the story is "just cause the tank looks really good on the outside doesn't mean it is on the inside"..
I also found the two objects in the last picture inside the tank. (top of one & bottom of the other) They looked like rivet heads that someone had dropped in, so I got my new telescoping magnet out to retrieve them. The magnet would not pick them up. (crappy magnet) I finally turned the tank upside down and fished them out of the sending unit hole. It wasn't the magnets fault, they were made out of lead.....
LockDoc
Leon
Old 12-14-2008, 10:32 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Be Sure And Check Your Fuel Sending Unit
Wow, I have never seen anything that looked that bad. I am glad you pulled that out, especially this early in the game.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-14-2008, 10:38 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
The lead pellets are from the 80's when they started with no lead gas. Some companies were selling them and saying to put them in the tank so you could still have leaded gas. I guess it was suposed to leach into the gas some how.
dwcsr is offline   Reply With Quote
Old 12-14-2008, 11:40 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
maybe that's what's in mine. when it is below 1/4 I can hear something metallic rolling around.
68C15 is offline   Reply With Quote
Old 12-15-2008, 01:37 AM   #5
caminokid
Chevy nut
caminokid's Avatar
I forgot all about that. I remember my dad telling me not to put them in my Firebird and GTO. Told me to buy the cans of lead insted.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 12-15-2008, 11:25 AM   #6
lks dcvn
lks dcvn's Avatar
That looks familiar...just changed mine in my Blazer over the summer this year - I was surprised with what I saw...not as bad as yours though.
http://67-72chevytrucks.com/vboard/s...5&postcount=33
lks dcvn is offline   Reply With Quote
Old 12-15-2008, 03:54 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
x2 I have/hear the same issue with my truck.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
