Old 12-15-2008, 01:46 PM   #1
7tredmach
collapsed radiator hose
Hi guys, great site, and alot of good looking trucks.
I have a question for a friend who has a 72 c-10 pickup. The truck has been completely restored and rebuilt, The motor has around 1,000 miles on it. The question I have, is what would cause the top radiator hose to collapse when he cuts the truck off after driving for a while. I've heard of the bottom hose collapsing while driving, but never heard of the top collapsing after driving.
Thanks, Paul
7tredmach is offline   Reply With Quote
Old 12-15-2008, 02:26 PM   #2
Bruce88
Bruce88's Avatar
Re: collapsed radiator hose
A bad or wrong radiator cap. When the engine cools down it sucks antifreeze back into the radiator thru the cap from the catch can, the valve in the cap can be bad or some times a wrong type of cap can be installed. Some older caps only allowed venting not allowing the sucking of fluid back into the system.
Bruce88 is offline   Reply With Quote
Old 12-15-2008, 02:26 PM   #3
Rack Man
Could be several different things...My first guess would be a faulty or wrong radiator cap...but it could also be a faulty thermostat or maybe a pinched overflow hose....Upper hose may just be bad as well....
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 12-15-2008, 02:33 PM   #4
cdowns
cdowns's Avatar
bad cheap rad hoses do that
Old 12-15-2008, 02:39 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Definately the cap.
--Josh
Old 12-15-2008, 04:19 PM   #6
7tredmach
Thanks for the info. He going to replace the cap first, then the upper hose if needed. What lbs. cap should he use? He replaced the stock 2 row with a 4 row radiator, and added vintage air during the rebuild. The motor is pretty much a stock 307 with 350 heads, edelbrock intake, and 600 carb. The truck is driven mostly durring warm, and hot weather, what degree therostat should he run.
Again, thanks for the info
Paul
Old 12-15-2008, 05:36 PM   #7
Wrenchbender Ret
If everything is in top notch shape he can run a 13 lb. cap. A 180 therm. works best.
Wrenchbender Ret is offline   Reply With Quote
