Old 12-15-2008, 08:38 PM   #1
sleepertruck72
sleepertruck72's Avatar
shortbed floor question
I am gonna pick up a fleetside shortbed that has a wooden floor in bad shape. My question is will a metal floor from a short fleet bolt up without too much trouble? I assume I will have to swap out braces underneath ? I searched this in the search section with no luck. Thanks for any help !
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 12-15-2008, 09:12 PM   #2
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: shortbed floor question
the wood/metal bedfloor swap is a direct bolt in , the braces under a metal floor are attached , the only part that you will need to swap out is the front bed panel , NOW I would like to ask if you do not use the wood floor brace's and rear cross member would you let them go ? my 67 has the metal bed floor and I would like to swap it to wood , PM me if you decide to let those go , thank's
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 12-15-2008, 10:59 PM   #3
sleepertruck72
19673ontree,
Thanks for the info. If I can pull the parts off without any damage I would be be happy to get rid of them. My 67 has the stepside with wood floor and I want to swap to the fleetside. I will keep you updated. thanks again
72 C20 Longbed
05 1500 Z71
Old 12-15-2008, 11:26 PM   #4
ANTHONY67
just change the front bed panel
ANTHONY67 is offline   Reply With Quote
