Old 12-15-2008, 10:02 PM   #1
hdflstf
hdflstf's Avatar
383/Vortec Temp Sender Help
Here's the deal. I've got a HT383 GM crate motor and the stock temp sender is too big to fit any holes in the manifold.
What are you guys using for a sender to the stock temp gauge on the vortec type heads/manifolds.
hdflstf is offline   Reply With Quote
Old 12-16-2008, 05:42 AM   #2
JimKshortstep4x4
Re: 383/Vortec Temp Sender Help
I used a set of late model heads on an engine with the smaller hole for the sender. I drilled and tapped the hole for our year sending unit. I tried getting the right small sender that would match the gauge and gave up after going to NAPA and other suppliers. The small unit may be available but I was not able to locate one that matched.
Another option would be to use pipe fittings to make an adapter.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
