Old 12-15-2008, 11:11 PM   #1
fleetmitch
fleetmitch's Avatar
Help with Paint Suppliers - Green 505
My paint guy says the local NAPA store cannot supply (I presume that means get the proper "ingredients") for Dark Green 505 - 1972 Chevrolet. What other sources could I seek out (e.g. national chain store)? What other colors are close? Thoughts on Woodland Green (paint code?) ?
fleetmitch is offline   Reply With Quote
Old 12-15-2008, 11:28 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Help with Paint Suppliers - Green 505
Try PPG, Nason & DuPont.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-16-2008, 05:32 AM   #3
JimKshortstep4x4
Chip Charts can mix the correct color for you. Here is a link if you want to check them out.
Jim
http://www.tcpglobal.com/aclchip.asp...truck-pg01.jpg
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-16-2008, 07:05 AM   #4
cdowns
cdowns's Avatar
check your yellow pages for auto body supply stores//napa is usually far down the list as far as being a complete service autopaint supplier
Old 12-16-2008, 06:49 PM   #5
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
I purchased my 505 green acrylic enamel from a Dupont jobber and I purchased the bc/cc (Ultra 7000 system) from Sherwin-Williams. They had to color-match the base, but it was near perfect with the acrylic.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 12-16-2008, 07:25 PM   #6
SactoJim
SactoJim's Avatar
You'll find that most paint mfrs. won't have older vehicle colors in their premium line BC/CC lines. Typically those colors will only be found in their SS (single stage) lines of paint.
Reason being is that they hand match all available colors for their premium line BC's which as you can imagine is very time consuming and tailored to the collision repair industry where most damaged vehicles are late models.
If you can't find a mix for your color, chances are you can get pretty close via a color book or using a color gun if you have a good sample of the original color to test from.
If you do have a custom color mixed to match, make sure you get the formula from your paint supplier because if you use all of it, it will be alot easier to match later if you should need more color.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 12-16-2008, 07:36 PM   #7
71BB_LWB
Thread Killer!
71BB_LWB's Avatar
I ended up taking a fender in to my paint shop so they could color match it. Even though my color shows up in the paint chips they did not have a formula in their system.
I know this may not help but it is my experience in the last few months.
Good Luck
71 Cheyenne SWB LS1 and auto.
http://67-72chevytrucks.com/vboard/s...d.php?t=256470
_____________________________________
If it's worth doing, it's worth doing twice...
Don't Mistake Honesty for Negativity...
71BB_LWB is offline   Reply With Quote
