Option G50 HD springs???
Have the parts but ---does anyone have this option installed on their 1/2 ton truck with leafs. Need to know how it all goes together----above or below spring, which end is front and which is rear as the center of the overloads is offset, what do the rubber ends bump up against? HELP!!!!!!!! Huck
The longer side goes towards the rear of the truck. Not sure what rubber ends you're talking about.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
If your taking about the overload spring that looks like 1/2 of a leaf, there for coil trucks. The mount saddle bolts to the rear of the frame and the wide end of the leaf slopes down and forward. There is a plate that mounts to the top of the axle housing with the U-bolts, that plate has the hole for the rubber bumper and it extends out back of the axle.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
