20" Coys C-5's (grey)
I purchased these earlier in the year for my 68 Beaters rebuild but the city code enforcement crackdowns have caused me to dismantle the project.
They're called C-5's because they fit over Vette C5 rotors & calipers (unlike ARE TT2's). The front wheels are 20x8.5's, 5.25"bs w/255-40-20's. The rears are 20x10's, 5.50"bs w/295-40-20's & they are the 5 on 5 truck bolt pattern. Tires are Toyo Proxes ST's w/about 10-20 miles. They were installed on my 68's rolling chassis for some pics of a C5 big brake kit & then again on my 74 for additional pics & one trip to the local cruise spot & have been stored in my garage since. I would prefer a local sale so you can personally inspect them which would eliminate any doubts . . ..... $1800 obo. SOLD!
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-16-2008 at 11:30 PM. |
Re: 20" Coys C-5's (grey)
Here's a pic of a 68 w/the same size tires so you get an idea of how low a truck will go w/them . . ....
67-72 parts collector,…
![]() Join Date: Nov 2002
Good deal for someone close.
What's going to happen with your truck?
#4 | |
![]() The front fenders & swb bedsides have been bodyworked & primed so they'll get wrapped & stored for future use/bartering. The SBC Dropmember goes on a shelf until summertime & will eventually find its way under my 74 (the C5 brakes will join as well). The frame will get 'tweaked' a little more, my C4 Dropmember will get installed & I'll swap the body from my RestoRod project onto it. The 350 (out of N2TRUXs' 77) that's mated to a 700r4 along w/the rear 12bolt, & the air aide system will find it's way to another 60's GM truck. I'm basically forced to put my build in a shop vs. out in my driveway. I figured my RestoRod has been waiting for so long that if I have to pay for any truck getting built @ a shop, it's going to be that one & not a beater.
I hate to see the death of your beater. I always liked that truck.
#7 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-16-2008 at 01:43 AM. |
Im in garland and my brother might be getting those from you.... I think. Just let me hear back from him so see if its a fo' sho thing.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
MY EX DRIVES A BROOM
im interestested, if i can get my hands on a five lug axle w/ 3.73 gears, or just some five lug axle shafts
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
Tot Roddin'
What a deal SCOTI... ttt!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Trade ya a $4000 Snap-On plasma to use on your other projects...
It's listed in the classifides if you are interested.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#12 | |
#13 |
Cool, thanks man. Let me know if you change your mind.
#14 |
Tightwad
Well do you have anything in stone yet????? Did you have them on your 68 with the body on at anytime? I was wanting to see what they would look like with my drop....
Eric
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
#15 | |
The pics of N2Billets red truck above has the exact same front size (the rears were a little different). In those pics, the truck has 2.5" dropped spindles, air bags, & stock GM style a-arms.
#16 |
Tightwad
Well what i have is 2 1/2 drop spindles and 2" drop springs in front and 4" springs and 1 1/2" drop blocks in the rear...fleet side bed i was just wondering if there would be any issues at my ride height....
Eric
#17 |
Heights would work w/your set-up. I know they worked on the red truck & it was approx +6" drop up front @ ride height.
#18 |
![]() Join Date: Nov 2008
what company makes these rims?
#19 |
Tightwad
I just may be interested in them... I sent you a pm with some more questions...
Eric
#20 |
Texas Big Wig
I know right
Not that you have the room, but would you be interested in trading for a 67 short step ??? |
#21 |
Tot Roddin'
These are made by Coy's Wheels.
#22 |
Tot Roddin'
As SCOTI stated, you shouldn't have any issues running these with that setup. Plus he already has the spacers for the caps. Buy them, mount them, and enjoy them...
#23 |
Tightwad
What do you mean by spacers for the caps?
Eric
#24 |
![]() Join Date: Apr 2005
Scotti,
A few questions: How tall are the front and rear tires? Did you have the narrow axle in back of your truck? (67-70?) I replaced the axles on the stock rear end on my 69 Burb, so it has the narrow rear end with 5 lug. I'm interested but would like to make sure the backspacing will work. Thanks, Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#25 |
Great Deal Scoti!
Eric, he is referring to the spacer between the center cap and the wheel. You can see it on the close-up picture above. Many of Coys wheels have center cap issues on this era of trucks, the center cap on the wheel interferes with the bearing cap on the hub. The little spacer that you see in the picture pushes the wheel center cap out enough so the bearing cap on the rotor will clear.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
