Old 12-16-2008, 12:15 AM   #1
87 dually burb
my short bus
87 dually burb's Avatar
raised flr/notches in burbs ??
how much are most people raising the rear floor
how much notch is needed to clear 20's
I'm hoping to only have to raise the floor 3-4 inches and build the seat bottom on the raised floor and use the top 1/2 of the old seat
if my layout works right hoping to do the dually in feb and the 91 in the summer
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 12-19-2008, 09:22 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: raised flr/notches in burbs ??
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-20-2008, 01:22 AM   #3
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
it really will depend on how you build your rear set-up. I went with a "bought" set-up that while being totally kick-@$$ raises the top of the notch 12" inches above the top of the stock frame. The quote from the supplier was "kiss your back seat good-bye". Of course he was refering the stock seat and my plans are similar to yours including trying to incorporate some sort of back seat into the notch cover. . I'll have more info to offer once I get the body back on, hopefully sooner than later.
I see that you're doing squares and mine is a '72 but I think the general process is similar.
I'm also trying to get my square dually on the ground some time soon so keep an eye for that too.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
