Old 12-16-2008, 01:33 PM   #1
westofb
I really hate wet sanding!
westofb's Avatar
changing frames
I have a 69 chevy long bed fleet side, am really wanting a swb truck and I have a 84 chevy swb frame. has anyone made this swap before? I realize the frame on the 84 has a 2 inch longer wheel base that a 69 swb, but I think moving the rear axle (springs and mounts) 2 inches forward would not be that big of a deal, just cutting off rivets and redrilling holes 2 inches forward. What I am unsure about is the width of the frames under the cab, the 84 is out in the snow and I don't really want to climb under it at this time to measure, but looks as if you could cut of the frame mount for cab mounts on 69 and bolt them to the 84 frame with little problems as long as the frames are very close to the same width under the cab portion of the truck. Any ideas or suggestions....thanks
westofb is offline   Reply With Quote
Old 12-16-2008, 01:46 PM   #2
lowriden58
lowriden58's Avatar
Re: changing frames
my advise is sell the 84 frame and buy a 67-72 frame, they can be had for cheap if you look around.
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 12-16-2008, 02:37 PM   #3
mycool72
mycool72's Avatar
Re: changing frames
X2, If you are willing to do a full frame swap ( I just did mine and it was a ton of work), then you should be willing to A. Modify you LWB into a SWB or B. buy a SWB frame, I picked mine up for 100.00
mycool72 is offline   Reply With Quote
Old 12-16-2008, 06:09 PM   #4
Mayo
Cool Truck
Mayo's Avatar
Re: changing frames
Not to hijack the thread, but would a 67-72 Cab and front clip fit on a mid 90s Chevy frame?
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 12-16-2008, 07:23 PM   #5
Boog
laying low
Boog's Avatar
Re: changing frames
I think it would be far easier and faster to just shorten the 69 frame rather than modify the 84 to fit the 69. You could have the 69 done in an afternoon and not have to remove the cab to do it. Cut the frame n weld and shorten the driveshaft or find a shortwheel base shaft. It has been well documented here on these forums.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-17-2008, 12:05 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: changing frames
if you are talking 2 wheel drive, then it's nor really a do-able swap. The frame on 67 - 72 is flat, the 73 - 87 is nothing close to flat.
