Old 12-16-2008, 07:09 PM   #1
renegade8720
How much Drop?
With the mustang II front end, how much does it drop the front of the truck verses the stock front suspension? Pondering weather or not to use standard spindles or drop spindles on my 1950 pro street build.
Thanks,
Rob
renegade8720 is offline   Reply With Quote
Old 12-16-2008, 07:12 PM   #2
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Re: How much Drop?
I believe 2".
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 12-16-2008, 07:46 PM   #3
mylow53
mylow53's Avatar
Re: How much Drop?
depends if your using a drop spindle. with a 2" drop spindle it should drag the frame or your transmission which ever is lower... my transmission is 1/8th of an inch off the ground with the air let out. i'm sure i could go lower with some shock mods but why!
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 12-17-2008, 04:19 AM   #4
renegade8720
Re: How much Drop?
I am going to be running 26" tall front tires, 29" tall Mickys in the rear. I don't want the front on the ground, but I want that classic hot rod rake.
Renegade
