12-16-2008, 07:43 PM | #1 |
Oil pressure question??
SB 4 bolt 350, how much oil pressure should I be running at idle, which I have at 900 rpm and how much say at 3400 rpm's which is about 65 mph? I am thinking my oil pump is not pumping as it should. I'm running 10/40 Valvoline. It will pump up real slow to about 35 lbs then as the oil heats it drops. Just curious what is normal. At temp it will Idle at about 15 to 20, at speed about 25 lbs. Normally operates at about 185 deg. I have an Autometer OP gage. Thanks, Mike
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
12-16-2008, 07:50 PM | #2 |
Re: Oil pressure question??
ive always heard 10lbs per 1,000 rpm.
12-16-2008, 07:54 PM | #3 |
dazed and confused
mine holds about 80 lbs at idle when you first start. about 35 lbs after it warms up 190. just rebuilt with a high volume oil pump. but it will go up to about 60 lbs at speed
12-16-2008, 08:57 PM | #4 |
I had heard the 10 lbs per 1000 before but what would be the max? Also what type hi vol would I go to. I know too much is as bad as too little.
12-16-2008, 11:58 PM | #5 |
You are in the range of most oil pumps. Ideally you want 15 lbs at idle and 30-45 at highway speed depending on the age of your motor.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
12-17-2008, 12:09 AM | #6 |
Thanks, I was getting worried. My get a higher prss. pump anyway though. Any suggestions of who what where, I know the when...preesh...
12-17-2008, 12:15 AM | #7 |
Mine's a Melling and it's a high volume versus a high pressure. I was told the high pressure can blow out normal seals fairly easily.
12-17-2008, 12:19 AM | #8 |
The original "Truck Data Book" from 1969 says for 350 engine " Normal Pressure (psi); 30@ 1170-2000 rpm".
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
12-17-2008, 09:58 AM | #9 |
10-15 at idle is fine and 40-80 at running speed is also fine. I personally would only use Valvoline Oil for lube on bicycle's. Most of the Pa oils contain trace amounts of parafin (wax) and will build up over time to form a thick waxy base on the head etc. Most shops and racers like high detergent oils that keep things clean like Castrol. I've run it in everything from $70K porsch's, vets, bmw's with never a build up or oil failure. My .02
