Old 12-16-2008, 10:33 PM   #1
hensonjd
dash
Im trying to cange my istrument panel on my 71 and i dont know how to get the windhsield wiper and light knobs out of the way so i can pull it off. Also what do yall think about clear versus the red led tail lights? thanks
hensonjd is offline   Reply With Quote
Old 12-16-2008, 10:41 PM   #2
t&tkennels
t&tkennels's Avatar
Re: dash
the wiper knob has a set screw, the light knob releases behind the dash from the light switch , theres a button on the switch , depress it an the it releases the knob
t&tkennels is offline   Reply With Quote
Old 12-16-2008, 10:48 PM   #3
hensonjd
Re: dash
What is the set screw and where do i find the depresser switch exactly?
Old 12-16-2008, 10:58 PM   #4
t&tkennels
t&tkennels's Avatar
Re: dash
the set screw on the wiper knob will take a small flat tip screw driver, grab the wiper knob as if you were gonna turn it on & feel with your finger next to the dash & you will feel the flat spot thats where the screw is. on the light switch , reach under the dash & feel around the light switch & you will feel the button , it will be on 1 of the sides of the switch . once you find it depress the switch the knob & shaft that goes into the switch will come out.
Old 12-16-2008, 11:05 PM   #5
72GMCburban
72GMCburban's Avatar
Re: dash
Funny story about that same thing. 1st time I tried to remove one I broke it right off! Then I saw the grime filled hole... this is still about the knob I swear
72GMCburban is offline   Reply With Quote
Old 12-16-2008, 11:12 PM   #6
yotaforce
Re: dash
Just took my kight switch out the other day while in the middle of teardown.....I was sitting on the rocker and when it came out, I punched myself in the face...HARD! I think I have a fatter lip. Warning: when you do find the release button, do not have face in front of switch!
yotaforce is offline   Reply With Quote
Old 12-16-2008, 11:30 PM   #7
72GMCburban
Re: dash
almost did that too. Good thing Autozone had 'em and not too much $ at the time.
Old 12-16-2008, 11:39 PM   #8
Gray Ghost
Gray Ghost's Avatar
Re: dash
The knob???
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-17-2008, 12:55 AM   #9
hensonjd
Re: dash
I got the windshield wiper off and i pushed the buton on the light thang but i cant get it to come off. Its not just coming off. Any help?
Old 12-17-2008, 01:04 AM   #10
mekdad
mekdad's Avatar
Re: dash
turn the lights to the on position then push the button and hold a little tension on it while wiggling the knob in and out and it should come right out.yes we are still talking about the knob.
you never know what you can do until you have to undo something you have done!
mekdad is offline   Reply With Quote
Old 01-15-2009, 11:19 PM   #11
moon
moon's Avatar
Re: dash
Here is a picture of that button
When the switch is in the dash, the button sits on top.
1970 CST long bed Fleetside
moon is offline   Reply With Quote
