Old 12-16-2008, 10:48 PM   #1
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Changing Coils, Why are they Loose?
Putting 3" Drop Springs in the frt of my 86, Is it Normal that they are a Loose fit while jacked up? Seems to be ok when weight is on them, Just don't seem Right that they fit so Loose................
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 12-16-2008, 10:50 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Changing Coils, Why are they Loose?
Thanks, Rick
thats normal, just make sure they go back in straight when you lower the jack.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-16-2008, 10:56 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Yep,... they are loose, because they are so short. If you have an alignment done,... make sure the springs stay in the upper seat area or your alignment will be off.
Keith
Convert to disc brakes.
Old 12-16-2008, 10:58 PM   #4
toomanytoyz
Luv the Crewcabs
Thanks Guy's,
I was more than a Little Concerned by this............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-17-2008, 12:31 AM   #5
slugish
Slugish
always jack it under the control arms right under the springs > otherwise they could get out of there sockets , I have 3 in springs as well
slugish is offline   Reply With Quote
