Old 12-17-2008, 12:06 AM   #1
pissonNOS
senior member
pissonNOS's Avatar
what parts would i need for a 5 lug swap
right now im 6 lug front and rear the truck is a 69 gmc lwb with a coil spring rearend, i bought the ece 6 lug dropspindle disc brake kit for the front so now what im wondering is would the 5 lug rotors be a direct swap for the front or do i have to do something else?? and as far as the rear could i just get 5 lug axles out of the same year rearend or what do you guys suggest? im mostly doing this for wheel choice.
Jason
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 12-17-2008, 12:46 AM   #2
SCOTI
SCOTI's Avatar
Re: what parts would i need for a 5 lug swap
You'll likely need the correct rotors for the spindles 'year model': pre-73 (71-72) or post-73. You can prob call the manufacturer of the spindles to determine what year rotors to purchase.
The rear is different. Longer 5-lug axles will physically fit into the shorter 69 rear housing but you'll have to re-configure the brake drums/backing plates. The better option is to replace those 38yr old axles w/some new ones w/the correct 5x5 pattern. ECE & Moser are 2 of the first choices I would look into. New axles that are 30% stronger than stock & have zero wear @ the bearing location is the better option IMO. Then all you do is add 71-72 drums & call it a day.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-17-2008, 08:02 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done this on an ECE kit. Just remove the 6 lug rotors and replace them with 71 and newer rotors.
They reuse the same bearings, seals and brakes.
No mods at all.
Old 12-17-2008, 03:23 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
ok thats what i was hoping i could do on the rotors, did u have to get the rotors from ECE or is this a parts store item i can get locally?
69 GMC bagged
Old 12-17-2008, 03:45 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
local parts store....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-17-2008, 07:47 PM   #6
Tx Firefighter
Yep, parts store or your favorite pre-owned auto parts yard.
Old 12-17-2008, 09:00 PM   #7
pissonNOS
senior member
pissonNOS's Avatar
good good its starting to look like i can do this for under$500 minus the cost of new rims and tires of course thanks alot guys does any one know tho how i would go about pricing axles from moser or anyone else would i need dimensions or just give them the application?
69 GMC bagged
Old 12-17-2008, 10:04 PM   #8
SCOTI
SCOTI's Avatar
Call Moser, tell 'em what year the rear end is & they do the rest. Add some 71-72 drums & you're done.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2008, 11:25 PM   #9
pissonNOS
senior member
pissonNOS's Avatar
thanks for all the help guys!!
69 GMC bagged
Old 12-17-2008, 11:47 PM   #10
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
if i wanted to use the 72 axles in my 68 rear, what drums would i need to look for at the parts place?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 12-18-2008, 12:13 AM   #11
SCOTI
SCOTI's Avatar
72 axles are longer than the earlier housing which requires specific offset backing plates & the right drums. I believe people use the HD 2.75" drum parts but I've never confirmed it. I've also heard of spacing the backing plate.
When I did mine I considered the used parts route until I opened up the rear w/the replacement axles & noticed the bearing wear that existed. I reconsidered & went w/Mosers stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
