Old 12-17-2008, 02:57 AM   #1
outlawc
The Outlaw 1968 build
Well, its been a loooong time but I finally started and have been working on my 68 build pretty steady lately. The truck I started with is a base model, 6 lug, manual brake/steering 1968 long wheel base truck with a good cab and body. I like these trucks low but after pricing everything I needed to drop it and convert/upgrade the worn out and outdated work truck suspension I decided to use a Camaro subframe. This will give me the drop I wanted, power steering, disc brakes, front sway bar, better suspension geometry and tighter handling. I used a subframe from a 1979 Z/28. Well, on to the pictures.
Heres the truck I started with
And the Z/28 subframe
First thing I needed to do was strip the truck down to just the cab and clean everything, I HATE working on nasty cars! Here it is stripped down and cleaned.
Getting the truck leveled and ready to seperate it from the trucks front suspension.
I started by taking any measurements I thought I would need then started cutting the front suspension several inches in front of the cab. This isnt where the actual cut needed to be but it got the suspension out of the way to make it much easier.
And its gone!
outlawc is offline   Reply With Quote
Old 12-17-2008, 02:58 AM   #2
outlawc
Re: The Outlaw 1968 build
Getting the camaro subframe ready to go in
Checking to see where and how far I needed to cut the truck frame to allow the subframe to slide into the trucks frame rails. I then cut the trucks frame where it needed to be cut.
The camaro subframe rails are wider than the trucks so it needs to be cut to allow it to slide in. I slid the subframe up to the truck to get an idea of how much needed to be cut off, squared it up and made the cuts.
Here it is with the extra width removed and ready to slip in the trucks frame rails.
Old 12-17-2008, 02:59 AM   #3
outlawc
Here its slid all the way in and I have started getting it squared, wheel base set etc.
View from inside to show how far the subframe goes inside the truck frame, 2 feet in all.
Old 12-17-2008, 03:00 AM   #4
outlawc
Once I felt everything was set right and square I tacked the subframe in and set it back on it wheels. I cut out most of the rear coils to drop the rear down to see how far it needed to come down. Its sitting on the bumpers and still needs a couple inches to be level.
Old 12-17-2008, 03:01 AM   #5
outlawc
Hung the sheetmetal to see how it was looking so far
Heres a better view with the cab removed.
Shortened the frame to a short wheel base.
And here it is with the Z/28 subframe and shortened
Old 12-17-2008, 03:02 AM   #6
outlawc
Now I can move on to the rear. I am installing a Posi, Disc brake rear end from a 1979 Trans Am to match the camaro width and bolt pattern.
Start by getting the trucks rear out and removing the axle brackets.
This is where I am at now, setting the pinion angle etc.
Old 12-17-2008, 06:37 AM   #7
northern 85
northern 85's Avatar
Wow thats progress! Keep us posted,Looks great
northern 85 is offline   Reply With Quote
Old 12-17-2008, 09:08 AM   #8
LuckyHenriksen
LuckyHenriksen's Avatar
Wow what a project! I like this pic
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-17-2008, 09:10 AM   #9
Puropedo
Really nice work there outlaw! A few questions,, are u planning on shortening the bed as well? How much narrower is the camaro clip track witdh than the stock 68 truck's? Most likely the cab is gonna get a tranny tunnel to compensate for the drop, right? Keep up the good work!
Puropedo is offline   Reply With Quote
Old 12-17-2008, 09:20 AM   #10
nuke1
nuke1's Avatar
that looks really good and low,, me likey, i just installed a cmamro sub frame in a 58, by the way is that a vette i spy in your first photo, what yr=ear is it, another pic would not hurt either, great job.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-17-2008, 09:29 AM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This is quite the project, nice work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-17-2008, 09:56 AM   #12
outlawc
Thanks everyone. I am enjoying building it.
Puropedo, I havent decided whether I am going to shorten the fleet bed or use a swb step bed I have on another truck. The track width of the T/A rear is about 4 inches narrower than the truck rear, the front I cant remember the exact measurement but its just slightly narrower than the trucks. I might raise the trans tunnel alittle, it clears but barely. I need to set the cab back on now since I have the mockup motor and trans set in place.
Nuke1, Its just the way I wanted it. Its all stock Z/28 ride height too, no drop spindles, no drop springs. The vette belongs to my cousin and I have been "storing" it for him for about 8 years now. Its a 76 Stingray.
Old 12-17-2008, 12:56 PM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Glad to see this build over here
Keep at it
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-17-2008, 01:16 PM   #14
outlawc
Thanks spraybomb! I thought that since I am actually making progress now and had something to show that I would go ahead start a build thread here too.
Hows yours coming?
Old 12-17-2008, 06:18 PM   #15
texanidiot25
Eat My Rust
texanidiot25's Avatar
That's flippin' wild.
Sweet build so far.
texanidiot25 is offline   Reply With Quote
Old 12-17-2008, 07:16 PM   #16
outlawc
Thanks texanidiot25.
Heres something I picked up yesterday in a local junkyard. I had been wanting one of these and just had to put it on today to see how it looks. Its a 1959 Impala wheel.
Old 12-17-2008, 11:03 PM   #17
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Originally Posted by outlawc View Post
Hows yours coming?
Freak'n slow !!!
I hope to get some junk done to it soon
Sinister
Killer
Old 12-17-2008, 11:40 PM   #18
outlawc
I know the feeling. Mine goes real good for awhile, then nothing for several weeks.
Old 12-17-2008, 11:53 PM   #19
cstm68
cstm68's Avatar
whats going on with the 69 camaro in the back ground of the pick with the sheet metal hung?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 12-18-2008, 12:17 AM   #20
ERASER5
ERASER5's Avatar
Nice!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-18-2008, 12:53 AM   #21
outlawc
Thanks ERASER5.
The 69 is a freinds car that I am one day going to restore for him. No new sheetmetal on the car yet, thats all original metal there. We took the entire car and had it stripped and EDP coated. Its a real 69 Z/28 but is missing the original motor, but I think he has acquired a rebuildable date correct motor for it.
Old 12-18-2008, 11:26 AM   #22
Puropedo
Outlaw, what is your plan for the rear suspension? Are u going to step notch
it? Bag it? Tell us! Love the steering wheel, that reminds me of a friend
who's got an 59 impala dash sitting in a shed at his back yard. Great project!
keep us posted
Old 12-18-2008, 03:24 PM   #23
outlawc
Yeah, I have to step notch it. The rear end is sitting on the frame right and still needs to drop a minumum of another inch to level it. So, I will have to make a small step notch for suspension travel because the axle tubes at ride height would be riding in the frame notch. I have bought a set of Firestone bags that I will run with seperate schrader valves and leave it set at ride height. I am thinking of running Hotchkis sport springs in the front which will lower it about an inch more so I want to be able to have some adjustment in the rear if needed.
Old 12-19-2008, 02:33 AM   #24
Puropedo
Great! I would love that thing to sport a short fleet side bed! U better shop that damn long thing up!
Old 12-19-2008, 05:43 AM   #25
nuke1
nuke1's Avatar
just to let you know, if you ever get tired of storing the vette, i have a nice heated garage up here for it, jsut to be helpful you know., lol
James
1968 GMC "HAVOC"
1986 GMC "Frank"
