Old 05-12-2002, 10:43 AM   #1
RED71CHEVY
RED71CHEVY's Avatar
Exclamation rear disc brake brackets for 12 bolt....
a while back a member had said he was working on brackets to be a direct bolt on to the drumbrake 12 bolt rear end (removing drums and bolting the bracket in place) and you could use rear calipers and rotors from a full size GM car........
does any one remember this post, or how i can get in touch with him.
TIM
'71 CUSTOM C-10,327,3.73 GEARS--NEVER ENDING PROJECT!!
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 05-12-2002, 01:39 PM   #2
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Post
caddilac conversion?
Charles W. Hein
S. Williamsport PA
imaindianoutlaw@yahoo.com
REFRIGERATION TECH
1971 Rolling chassis
FOR SALE
1963 Pontiac Tempest
1965 Pontiac GTO
1956 Pontiac 2 dr
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 05-12-2002, 03:50 PM   #3
RED71CHEVY
RED71CHEVY's Avatar
Post
yes i believe you could use the caddy calipers.
TIM
TIM
Old 05-12-2002, 11:51 PM   #4
dan71
Post
I got a set off of the back of a 77 caddy. You will have to do some work to get them on,but they will fit. I am not sure how well they will work yet because the truck isnt back up and running. The bolt pattern is the same as the truck. The axle flange's have to be turned down enough to fit inside of rotors,and redrill holes in the caliper backing plate to match the axle tubes. Change the proportioning valve at the master cylinder to one from the disk/disk caddy.I think that is about it. Hope this helps!
dan71 is offline   Reply With Quote
Old 05-13-2002, 08:57 AM   #5
slam33
slam33's Avatar
Post
As far as I can tell, you can use up to 79 Caddy that had a 5 on 5 bolt pattern and a 12" disc
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
