12-17-2008, 08:19 PM | #1 |
headers with a 3spd
i've been searching the forum for this answer, and can't find it.
i have a 67 c10 swb fleetside, originally a 6cyl w/ a 3spd on the column, it is now a 327 and has been converted to a floor shift, i would like to install a magnaflow exhaust system and want to know what headers would work with the least modification, i would prefer long tube, but whatever works. someone here in town has a set of flowtechs that are supposed to fit this truck, but he doesn't know the model # i just found this forum today, and i haven't been able to stop reading it yet. i'll post pics of the truck as soon as i can. |
12-17-2008, 08:37 PM | #2 |
Chevy nut
Re: headers with a 3spd
I had a set of Hooker super comps on my 69...350 3 speed converted from column to floor
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
12-17-2008, 08:55 PM | #3 |
We had to modify the clutch bellcrank to clear the cheapee Summit headers.
12-17-2008, 09:12 PM | #4 |
I too have been searching to no avail. I even called Summit and they dont list any (longtubes) for a man. trans. truck. I have Blackjacks (old) on now and need some with large O.D. ...Looks like its Hammer time again.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
12-17-2008, 10:02 PM | #5 |
my 78 has a 350 with a 3 speed and flowtech longtube headers and they fit fine, its still column shift though.
12-18-2008, 12:57 PM | #6 |
i called jegs and they said the 30055 jegs long tube headers should fit with no major modification
12-20-2008, 10:14 AM | #7 |
I used block huggers with out any issues... couldnt use longtubes because of ground clearance.
12-20-2008, 02:18 PM | #8 |
This is no help ,but the 70 we have had long tube headers .I don't know the brand cheap i'm sure . They fit great ,but the z bar fit in between the tubes .Had to remove it to remove headers on driver side .
12-30-2008, 09:50 PM | #9 | |
any insight would be great. |
