Out of the carpool lane.
I got a new seat cover & foam and although I'm not sure I'll keep it, if I do I want to install it correctly without any issues. It would seem pretty straightforward to me, but will it be easy or is there a trick to installing one so that it fits well?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
Re: Is there a trick to installing a bench seat cover?
Brad, I installed mine back in the summer. I would recommend picking a very hot day and let the cover lay in the sun for an hour or so before installing it...but those days are few and far between, especially in Oregon at this time of the year. Your best bet is to turn the heat up in the room/garage that you plan on working in. Just make sure it is soft and pliable. Post some pics for us.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
![]() Join Date: Jan 2008
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
Active Member
![]() Join Date: Jul 2007
Agree with the above. Summer is best or a warm garage. Spray silicone will also help to slide the covers on.
![]() Join Date: Jul 2006
if you're not concerned with factory "correctness" try using black zip ties instead of hog rings (shouldn't see them anyhow). they're easier in my opinion. Don't forget to put new burlap between the foam and springs, otherwise it will cut and sag.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
i will have too do a seat next year also
#7 | |
I saved the burlap from the old seat, but it was only on the seatback. Should the seat portion have burlap also?
Yes especially the seat bottom, because that is the part, that takes the most wear. And do not use zip ties, I do upholstery work!! Hog rings are cheap and easy to install/remove. Burlap is cheap also, I just bought some tonite for a seat im doing, the expensive stuff was only 3.49 a yard. So replace both back and bottom.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 12-18-2008 at 02:43 AM. |
I just found this over at Brothers:
http://www.brotherstrucks.com/techar...20INSTALLATION
i've always put the seatcovers in the dryer for 15min or so prior to installing and had a hair dryer handy during the install for streaching and wrinkle removal
I did mine a year or so ago. It came out good but I didn't realize it had a broken spring. It poked a hole in it.
