Will 10 inch wide, 4.5 inch backspacing wheel vintiques truck rallys fit on a step side shortbox 1/2 ton two wheel drive pickup without clearance issues.
Old Skool Club
![]() Join Date: Jun 2001
Re: 10 inch wide corvette rally's
I have 15x8's with 4-inch backspace on the front, following a disc conversion. In the rear, I'm running 15x10's with a 5-inch backspace. The '67-69 rear axle width is narrower than the '70-72. I've read that someone running the later axle found that the wheels stuck out to the edge of the fenders when running a 5-inch backspace.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
