We have to admit it, stock engine mounts on our trucks are not the greatest. So here is my idea. If we can take a 73 and up front cross member, and bolt it to our truck frames, why not use 73 and up engine towers, and up grade to the 73 and up mounts? This way we can also have urathane mounts, and the 73 and up are a better set-up. When I swap engines this winter, I'm gonna up grade to a 78 front cross member, and I'm thinking of using the 78 towers and mounts. What do you guys think? Has anyone tried this? Please let me know. Thanks, Jason.
Post Whore
![]() Join Date: Feb 2000
Blazerman gave me a scanned article a while back that recommends when doing a big block swap into a 4wd, that you use the 73-up cross member and towers. My question is, are the 73-up cross member and towers different for 2wd and 4wd and big block and small block. The article didn't mention that. I will be interested to follow this post.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I know that 2x4 and 4x4 are diffrent crossmembers.
Fabricate till you "puke"
Racedvl, I havent tryed the later mounts on a sb, but dont see why they wouldnt work. you would have to drill the holes on the top of the frame for the stands, & may need to play with positioning of the engine(the 73 up trucks seem to set the eng closer to the firewall),but IMHO a little engine setback is good. I have used late 70's stands, & deisel brackets to mount a 455 Olds in the longhorn.......i got 1 bolthole on the top ea side to line up, & drilled the 2. At the bottom i welded the stands to the 69 crossmember. Good luck.....crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Hhhhmmm. I'm thinking that if the lower part of the 67-72 towers bolt to the 73-87 cross member, that the bottom part of the 73-87 towers should bolt to the cross member, right? Then if ya gotta drill the frame. . . oh well. what does anyone else think?
Drilling the holes on the top of the frame rails shouldnt be a problem,& if you are using the later crossmember, you will have the holes at the bottom.......I couldnt get the later stands to bolt to the early crossmember tho.....(at the rear was the issue)
i love summertime
my 67 is sitting on a 85 swb frame....therefore im using all the newer sh!t, i didnt notice a whole lot of difference from the 67 mounts and frame...i got pics of the 85 frame if you are interested
Derek ![]()
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
its all about the +6 inches
Jason, if you drill into the frame rails...I recomend a 1/2 inch drill and not a little 3/8 inch wussy one.
Heck, I killed my 1/2 inch one going into the Longhorns frame rails the other day. |
1/2" air drill......couple drops of earl, & you can run em all day,or till they wear you out
Yukon Jack
Quote- " My question is, are the 73-up cross member and towers different for 2wd and 4wd ? "
Yes and right now I am looking in to this . The 73 + 2WD towers go from the frames top rail to the suspension crossmember. The 4WD towers do not leave the frame rails ( the 4WD of course has no suspension cross member ) but the 4WD towers do have a narrow steel brace that goes directly across between them to make up for that lost support . I picked up a set of 84 2WD towers and even though the holes at the top rail match I can see problems at my 67 suspension crossmember . I am going to measure it out to see if I can some how use the frame rail only 4WD towers if the rails are the same height and are the same spacing apart and if it will not put the engine to high it might work . |
Post Whore
Great information, will need to file this post away for future reference.
LATTER TOWERS
To follow up on the post I made above to Yukon Jack , today I took out the 6 CLY towers on my 67 C20 and tried the 84 burb 2WD towers and they will fit perfectly if I redrill 3 of the holes. The bottom of the towers even followed the contour of the 67 crossmember exactly . Then I swung the 454 in to the engine bay , This is a 1977 - 454 with standard motor mounts , it went in and lined up with the holes in the towers so well that I was able to drop the motor mount bolts in by just wiggeling the engine a couple of times and it turned out to be the easiest drop in I have ever done . Like other 67's and a big block the top edges of the valve covers come close to the fire wall corners , so when the engine comes out to redrill the tower mounting holes I will also elongate the holes so I can get some adjustment if I need it . For those of you that are thinking of a BB in a 67 , these towers work.
#13 | |
Bloo
i cant add anything to the mount question, but i can say that i drilled 4 1/2 inch diameter holes in my frame with a hammer drill... so it can be done (1/2 inch drill)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
![]() Last edited by Blue_71; 12-04-2002 at 12:23 AM. |
