Old 12-18-2008, 12:02 AM   #1
BluTooth
Converting from generator to alternator
I have a 57 pickup and this is my current wiring to my generator. Can someone suggest what I need to do with the wires going to the regulator and which ones go to the alternator when I replace my generator with an Ultima 63 amp alternator?
thanks,
BluTooth is offline   Reply With Quote
Old 12-18-2008, 10:40 AM   #2
bensimmons_05
bensimmons_05's Avatar
Re: Converting from generator to alternator
Is the alternator internally regulated?
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 12-18-2008, 10:51 AM   #3
JML55
JML55's Avatar
Here a simple wiring diagram. The only wire you keep from the old regulator is the battery wire. You will conect to bat tem of new alt. The field and arm wire can be remove as well as the old regulator. That is of course if you use an alt with integrated regulator. #1 goes to the dash warning light and #2 can go right back to bat term of alt.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 12-18-2008, 11:15 AM   #4
BluTooth
Yes, it is internally regulated. The drawing really helped.
