rear tire clearance
I'm sure its been posted before but what is the widest rear tire you can run on a 1968 short wide with trailing arms? Stock hight and keeping it in the fender.
accepting donations
Re: rear tire clearance
bump
I'd like to know as well as with 4" lowering springs.
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
Me too
#4 | |
Larger diameter wheels? 295-40-20's on 20x10's w/about 5-5.50" BS fit pretty easy & maybe a 315-35-20 on an 11" can be squeezed in if everything is equal & set-up properly. Even larger diameter? 285-30-22's on 22x9 - 10's w/5-5.50"BS. Smaller diameter but wiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiide . . ..... 31x18.5x15's w/Mickey T Sportsmans on 15x14's custom back-spaced wheels will fit if the wheel tubs are widened. Pick your poison ![]()
Mmmmm I like the sound of those Mickeys
