12-18-2008, 09:36 AM | #1 |
MidlifeCrisisUnderWay
Brand New Aluminum Radiator
It has never been installed; just taken out of box for inspection. Still have all packing/shipping material.
Radiator is specifically for '67-'72 Chevy Blazer and trucks (OEM replacement). $195 plus the ride. Located in Boise, ID I have Paypal. |
12-18-2008, 11:08 AM | #2 |
Re: Brand New Aluminum Radiator
Who makes it? Is it a 4 core radiator? Does it mount with the factory brackets?
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-18-2008, 12:30 PM | #3 | ||
Classic Radiators. They're stock replacement fit. From the eBay auction where I bought it: Quote:
The eBay page. |
12-18-2008, 04:12 PM | #4 |
How wide are the core tubes?
I think most aluminum radiators are 1 in tubes, but some are wider, (and some narrower I'm sure). My Griffen has 1-1/4 in tubes. I'll do some measuring and see if I could use my Griffen in my Sonoma. If so I'd be interested in yours.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
12-20-2008, 01:10 AM | #6 |
Can you tell me how this thing mounts,it doesn't look like stock mounts will work.Also, what size hoses does it take?
Thanks Jim |
12-20-2008, 12:38 PM | #7 |
CDA maybe this will help. I think I bought the same one from ebay. The top factory mounts work but it could look better. Here's a few pictures of mine mounted. I'm going to replace the top mounts as soon as the rest of the truck is together.
12-20-2008, 02:14 PM | #8 | |
Thanks for the pics !! |
02-10-2009, 01:35 PM | #9 | |
BTT Price is OBO |
02-10-2009, 02:33 PM | #10 |
What is the extra hole for? The one with the black cap on the right side.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-10-2009 at 02:35 PM. |
02-10-2009, 02:49 PM | #11 | |
Tranny cooler line. |
02-10-2009, 03:04 PM | #12 |
OK, I'm confused. There's 2 gold holes (tranny??) and one black one (??)......
02-10-2009, 03:08 PM | #13 | |
Yeah know, I am too now !! |
02-10-2009, 03:20 PM | #14 | |
I'd think it'd be the return from the heater core but it looks awful small. Any dimensions on this thing? (H,W, core size)
02-11-2009, 03:02 PM | #16 | |
R
02-11-2009, 05:01 PM | #17 |
It's not the heater return it's for a sensor. Mine came with it. Not something you have to use.
02-11-2009, 05:48 PM | #18 |
I would like to use it for the steam port on an LS engine, but I want to make sure it actually goes into the water jacket of the radiator and not into the transmission cooler.
02-11-2009, 06:03 PM | #19 |
I bet it can be used for that hart-Rod. The only concern is that it would actually flow water through the steam tube. If I remember, doesn't the steam tube have to come in to the radiator above the water line and release into the system. If it is below the water line wouldn't it just put water in the tube? It could be used for a fan controller.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-11-2009, 06:15 PM | #20 |
Eat My Rust
The stock mounts will work with some work. What we did is cut the rubber isolater down some so that the mounts would hold it flat against the top of the radiator. Then the filler neck side had to be cut to clear the cap. Once done, the top mounts sat flush with the radiator and it looks good.
Mine is a 4 core version, cools like a mother. |
02-13-2009, 02:28 PM | #21 |
Under Construction
I emailed the Ebay Seller about the extra port on the passenger side, and this was his comment....
That would be a heater return. It's there if you need it but if you don't you don't have to hook it up either and it'll still work fine.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
02-13-2009, 03:21 PM | #22 |
150.00 shipped?
02-13-2009, 06:43 PM | #23 |
Pm sent
70 SWB STEPSIDE 70 BLAZER 09 challenger |
