Old 12-18-2008, 11:46 AM   #1
dznucks
dznucks's Avatar
Bearing Race Removal
How do you remove the bearing race from a rotor? is it machined out or pressed out?
dznucks is offline   Reply With Quote
Old 12-18-2008, 11:53 AM   #2
2quick4u
Re: Bearing Race Removal
wipe the rotor out...you see an indent in the rotor where you can put a punch or the back lip of the race...from the opposite side hold the punch in the indent and hit with a ball peen or mallet hammer...after you feel it move some...go to opposite side of race and look for lip...place punch on lip and drive it on out...or old school...heat with a torch till red and turn it over and watch it fall out...good luck
2quick4u is offline   Reply With Quote
Old 12-18-2008, 03:32 PM   #3
cdowns
cdowns's Avatar
i've always just used a chisel punch or screwdriver wichever i grab first to knock it out from the rear//never had a problem doing it that way
Old 12-18-2008, 06:43 PM   #4
dznucks
dznucks's Avatar
ok cool. i wasn't sure if it was that easy.
thanks
Old 12-18-2008, 07:13 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Make sure you use a Brass punch or wood when reinstalling.You don't want to use anything that might mar the new race.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-19-2008, 02:14 AM   #6
Aarons72s
Another trick to get the new ones in is to place the old race on top of the new race and tap on the old race till the new race is in.
Aarons72s is offline   Reply With Quote
Old 12-19-2008, 03:09 AM   #7
ERASER5
ERASER5's Avatar
X2
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-19-2008, 03:15 AM   #8
El Jay
Gone to greener pastures
Use the old race "backwards", so you have a "lip" for driving the old race out.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 12-19-2008, 06:53 AM   #9
PanelDeland
Refrigerate(put the new one in the freezer for about an hour) and it should almost drop in.
Old 12-19-2008, 07:22 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I take my welder and run a bead inside the bearing race. It will shrink and fall out when it cools.
Old 12-19-2008, 09:40 AM   #11
70 Suburban
Rods
hmm thats a new one.. I have heated the outer surface. but the welding thing sounds like it would work.
70 Suburban is offline   Reply With Quote
Old 12-19-2008, 09:54 AM   #12
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
yea but by the time you weld the bead you could have already just used a punch and knocked it out. Its not that hard. Just sayin ... cool idea though.
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
Old 12-19-2008, 11:49 AM   #13
dznucks
dznucks's Avatar
great info.
i have the ECE drop spindles and disks. do they use the stock bearing or do i need different ones?
Old 12-19-2008, 01:20 PM   #14
Tx Firefighter
Sure, here. But some other applications have blind areas where races can't be pressed out (ie Harley XL steering head bearings) and that's a good method to have in your head. I like to be the go-to guy in a shop for difficult problems.
Old 12-19-2008, 01:20 PM   #15
Tx Firefighter
Originally Posted by dznucks View Post
great info.
ECE rotors and spindles use stock bearings and seals for 71-87 HD truck rotors.
