12-18-2008, 12:59 PM | #1 |
Didderent Alternator and HEI ?
Im running a 105 amp alternator with a 10 ga. charge wire. If I didn't want to use a fusible link what size fuse would I use. Same question for the HEI. What size fuse should I use for the power wire to the HEI.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
12-18-2008, 04:13 PM | #2 |
Re: Didderent Alternator and HEI ?
I know you don't want to use a fusible link but do it anyway. You will have to use too big a fuse to keep from blowing them out all the time and when you do have a problem (short etc.) you are more likely to burn something out than with a fusible link.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
