Bed Fill- Tips On Cutting Hole
I am preparing to install an under bed fuel cell with a bed floor fill, do you have some tips/advice for cutting the hole? And what do you use as a door?
Thread Killer!
Re: Bed Fill- Tips On Cutting Hole
I used a filler from an S10, including the internals. I modified the tube to fit what I needed.
When you open the door it looks just like a newer car. As far as cutting the hole, I made a templete out of heavy paper and moved it around as I needed it. I measeured many times to find the best spot (IMO) for it and to have the least cutting of the bed floor and side wall. Dan
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... |
Looks nice, but I am looking for a simple hole in the floor. Anyone have pics?
Thread Killer!
OOPS, I missed that part of it, but lots of guys have done it did you try a search?
![]() Join Date: Oct 2005
Here's mine......a little more involved, but turned out good.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Wow that looks great! Just what I was thinking. I tried searching several different terms, but kept coming up with the trick marker light and flip down tail light fill ideas. I can't weld, and have little to no fab skillz so I need something that is simple and looks decent. Sacto, I am going to search your build thread for more info on yours, if its not in there, I am going to ask lots of questions! Thanks for sharing.
Oh and where did you get your fuel cell? Its beautiful
Never Ending Projects
If you can't weld (or find someone who can), your options become very slim. Outside of just installing a boat style filler directly into the bed floor, you're not going to have many other ways to do it. BTW, do you have a wood or steel floor? That will make some difference.
Good luck.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
I have a steel floor. I think this is a perfect excuse to find a used welder and learn how to do it! I like how clean and flat the door is.
Oh and Sacto, I just read through most of your build thread, and see that its a FCG tank. I ordered one from him, and I am excited to think that it will look similar to that!
