Moderator
![]() Join Date: May 2007
Pinion angle when lowering the rear
I am going to lower the rear of my truck with 4" coil springs. I have 2" lowering blocks now, which I am going to remove, so I will have 4" lowered total with the springs. Will I need to correct my pinion angle with degree wedges? I used to lift Jeep CJ's a long time ago, and had to use wedges to correct the pinion angle. Thanks for your help.
Under Construction
Re: Pinion angle when lowering the rear
I asked ECE this question when i ordered our drop kit from them (4" rear drop springs) and they stated we would not need to make any adjustments. I would like to know as well. we may go with a 1" or 2" blocks later down the road
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Moderator
Thanks for your input. I may end up putting the blocks back in if it is not lowered enough for me. I wonder if lowering it in the front compensates for having to shim the rear pinion?
I have 4" springs and 1" blocks and the angle is ok.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
I have 4 inch springs and am in the process of building 2 inch blocks, I hope it doesn't need adjustment.
Moderator
ya it does fine. I dont have any shims, the rest is stock
Moderator
Cool...how much are you lowered in the front? I am thinking if I lower it proportionately, it will help keep the pinion angle consistent.
I have 2.5 spindles and 1 inch springs. I am thinking of hacking half a coil out to go with the blocks, making it a 4/6
Moderator
I have 2.5 spindles in the front, and am wanting to go with 1" springs to lower it just a little more. I was very pleased with the spindles when I put them in last year. I currently have 2" blocks in the rear with stock springs.
I would sell you my front springs (they are brand new) but I cant afford to buy another set, so I have to do with cutting them
Moderator
No problem Lucky...I will keep lookin! How is your ride with the 1" drop springs in the front? Do you bottom out at all? I love the spindles because it did not affect my ride quality at all. How about alignment? Did the shop have any trouble aligning it with the lowering springs?
#13 |
![]() Join Date: Jul 2005
Not sure may be this would help a little bit
http://www.carcraft.com/howto/91758/index.html
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
#14 |
It rides really nice, surprisingly smooth for an old truck. I havent had any problem bottoming out, scraped a header collector on a speed bump at school though.... that was my own fault for driving too fast. I had no problem getting it aligned, the guys at Les Schwab was very helpful and didn't have any trouble getting it on the rack or anything.
#15 |
Retired Air Force Veteran
![]() Join Date: Aug 2007
leddzepp, I have 6 inch rear coils (no c-notch...yet) and my pinion angle is fine. I too, called ECE about this and here's what they told me.
1"-2" use the stock track bar 3"-4" use an adjustable panhard bar 5"-6" us the super track bar This will keep your pinion angle geometrically correct
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
#16 |
great link larry
#17 |
I have 4 inch springs and will be adding 2 inch blocks, does this count as a 6 inch drop? I don't want to have to buy a super track bar.
#18 | |
Moderator
#19 | |
ECE states minimal pinion change w/up to 6" spring drops. Any more than that, you'll want to combine springs & blocks for sure.
#20 |
Not to hijack, but how about the pinion angle with bags and just a c-notch?
#21 |
Bump.
#22 |
It's my understanding that pinion angle is in relation to the crankshaft/transmission shaft centerline. When you use parallel blocks the angle of the rear diff doesn't change. Shorter springs cause the trailing arms to rotate changing the angle. What's too much, I don't know.
Bags should be evaluated at desired ride height. If it's 6" then according to ECE you're OK. If you want 8" then add 2" blocks. |
#23 |
#24 | |
Moderator
![]() Good info here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 10-03-2009 at 10:11 AM. |
#25 |
