Old 12-18-2008, 06:48 PM   #1
caminokid
Chevy nut
caminokid's Avatar
Bed mounts
I noticed something when I was putting the bed on the frame I am using. The mounts above the axle are taller then the ones on the 3/4 frame. The bed has a wood floor. The bed that was taken off has metal floor. why is the mounts different? You would think that the mounts would be the same as the other. I cut the heads of the rivets off of those mounts so I can replace them when I am ready.
Here is the frame I am using. The mounts here are mounted to the sides of the frame.
These mounts are at the left edge of the pic. they are in a totally different spot.
Now that I look at it...there is two center mounts on my frame...and none on ther 3/4 frame.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 12-18-2008, 08:21 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Bed mounts
The angle mounts in the first pic have been added by someone. They are not stock. Maybe for a fifth wheel or gooseneck trailer mount.
LockDoc
Leon
Old 12-18-2008, 08:44 PM   #3
caminokid
Chevy nut
caminokid's Avatar
Re: Bed mounts
LockDoc
I guess I didnt think about that being a 1/2 ton frame. But then again it has overloads on it. Thanks. I know I have to remove them. They are pushing the floor up on both sides.
Old 12-18-2008, 08:49 PM   #4
sameyrasmea72
sameyrasmea72's Avatar
Re: Bed mounts
The only bed mounts you need are the front three. The ones are for a swb, and the ones and the two are used for a lwb.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-18-2008, 10:19 PM   #5
caminokid
Chevy nut
caminokid's Avatar
Re: Bed mounts
It does make sense. I guess those four mounts threw me. This is my first 67-72 restore.
Old 12-19-2008, 11:07 PM   #6
caminokid
Chevy nut
caminokid's Avatar
Re: Bed mounts
well i got out there and got a real good look at those mounts. I didnt realize they were welded on. I got to grind the welds off when I get a chance.
