Old 12-18-2008, 08:55 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
OEM Horn Replacement
Anybody replaced the anemic sounding stock horn with something that has a little more balls?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-18-2008, 11:29 PM   #2
cdowns
cdowns's Avatar
Re: OEM Horn Replacement
before tossing horns give them some lovin//clean the mounting surfaces where they mount to the core support shiney metal to shiney metal gives a good ground //also spraying wd40 inside while energized will help clean the diaphram and polish the plate it vibrates against resulting in a factory type sound and a last resort after those things is the little adjusting screw to dial it in
