Old 12-18-2008, 10:32 PM   #1
grancuda
grancuda's Avatar
Looking to swap 250 I6 for 350, what engine should I get?
What is the best motor for the money as far as small blocks go? I am looking at the 290hp 350 GM Crate engine which is about $2000. Also, considering going with a short block and getting a set of Edelbrock heads that way I can get a little higher compression for a little more power. Anyone recently put a small block in thiers?
grancuda is offline   Reply With Quote
Old 12-19-2008, 11:11 AM   #2
grancuda
grancuda's Avatar
Re: Looking to swap 250 I6 for 350, what engine should I get?
This was my last project like this, it was a '69 Dart w/225 slant 6 and I put a 360 MP crate short block w/edelbrock heads, TF904 w/low gear set and 8-3/4 w/2.91 sure grip. It was my daily driver and was good for around 400hp, 15mpg highway and 13.11 @ 115mph 1/4 mile times. I don't want to make the truck a racer but do want some more power for sure.
Old 12-19-2008, 11:23 AM   #3
nightmare
nightmare's Avatar
nice dart. just recently acquired a '70 duster with the slant 6. strong little motor, although i haven't had it on the road yet. got any more pics?
as far as swaps, i haven't done one recently, but a friend of my dad's built the motor that will be going into mine. i just need to get a 700r4 so i can transplant everything at one time.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-19-2008, 11:33 AM   #4
Bruce88
Bruce88's Avatar
I believe the GM 350 crate engine is a good value for the money. Since you talked about Edelbrock heads you might want to go to Edelbrock and check their crate engines out, might be able to save more than gathering all the parts separately.
http://www.edelbrock.com/automotive_...nes_main.shtml
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 12-19-2008, 11:43 AM   #5
1tigers
I bought a 5.3 with 4l60 trans pull out.It has 30,000 mi. Got it for $800.00.It will make 375 rwhp with a cam in it .spreartech will do a harness and program for about $600.00 .Great fuel mileage and reliability.
1tigers is offline   Reply With Quote
Old 12-19-2008, 11:46 AM   #6
LuckyHenriksen
LuckyHenriksen's Avatar
Definitely go Gen III
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-19-2008, 12:26 PM   #7
grancuda
grancuda's Avatar
With the Gen III can I run my 3 speed manual, is the bell housing the same bolt pattern?
Old 12-19-2008, 12:50 PM   #8
LuckyHenriksen
Mmmmm Im not sure, I know some guys have kept their muncies behind Gen III's, someone with more experience can answer that for you
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-19-2008, 12:52 PM   #9
BluTrukker
BOHICA
BluTrukker's Avatar
I hear the 409 is being brought back from the dead and recast, that would make a unique combo.
BluTrukker is offline   Reply With Quote
Old 12-19-2008, 01:35 PM   #10
mrein3
mrein3's Avatar
Just get a vortec 350 out of a 95-99 truck. EVERYTHING you got bolts up to it. All you need is an intake manifold made for a carb that sits on this engine in place of the fuel injection setup and your done.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
