12-19-2008, 12:10 AM | #1 |
Navy Radioman Veteran
Mating a '78 Camaro Front Clip on my '57 Stepside?
Hey guys,
I've been slowly rebuilding a '78 Camaro for the past 2 years. I'm considering scraping the project and using the sub frame for my '57 Stepside. It has been completely rebuilt with new Energy Suspension bushings, rotors, brakes, motor mounts and shocks. Can the clip be welded to the frame rails of the '57? Thanks in advance! Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside Last edited by 87Lowrider; 12-19-2008 at 12:13 AM. |
12-19-2008, 02:00 AM | #2 |
Re: Mating a '78 Camaro Front Clip on my '57 Stepside?
Hi Kenny
I'm not sure of the track width on the 78 camaro but if it is the same as or close to the 57 then it can be done. Guys have used the 1st gen sub frames without any problems. Kim |
12-19-2008, 12:56 PM | #3 |
Yes, there is a guy around here that does it all the time to 57-59's. Uses the front clip and rear end. Do a search there is probably a thread on here showing it. The splice point is a little messy because the camaro frame is not straight and box shaped at the splice.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
12-19-2008, 01:36 PM | #4 |
Junior Member
The 2nd gen clip is the better choice over the 1st gen so yes you can do this:
I strongly suggest you read this tech article: http://www.jalopyjournal.com/forum/s...ht=Camaro+clip some great stuff in here. I haven't done this yet but Im planning to do this very soon to my 59. -Andy |
12-19-2008, 02:03 PM | #5 |
You can check out my thread, I installed a 74 Trans Am subframe, same as the 78 Camaro.
http://67-72chevytrucks.com/vboard/s...d.php?t=220256 |
12-19-2008, 07:16 PM | #6 |
Thanks guys,
I have the rear also but am planning on using my '73 Jag XJ6 IRS for it instead. Looks like I'm starting back on the truck a little quicker than I had planned. Might even have it on the road in '09. Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
12-20-2008, 12:32 PM | #7 |
i also installed one in the 58, check my sig, lowered it 7 inches over stock. used a 79 camaro
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
12-20-2008, 01:04 PM | #8 | |
Lots o info there. Gonna be a while till I get through it. Thanks!! Kenny
12-20-2008, 01:11 PM | #9 | |
ME LIKEY! Kenny
