Old 12-19-2008, 12:13 AM   #1
smoked68
smoked68's Avatar
No tail lites, blinkers...its dark..Help
Hey guys, a guy flagged me tonight and told me I had NO LIGHTS at all in the rear. Sure enough, no running lights and turns dont work. I checked the fuses but it was dark and I dont see too good up close at night. Anyway in the a.m. I must find the prob. No Brake lights either. I will check the plug in the back in the a.m. also but any more suggestions would be appreciated. Thanks, Mike
I work the afternoon shift so I will be driving at night again. No brake lights scare me so thanks in advance for the help.
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 12-19-2008, 12:25 AM   #2
smoked68
smoked68's Avatar
Re: No tail lites, blinkers...its dark..Help
Could it be the light switch? The head lights and front turns workThe no brake lights has me baffled??? Cant sleep now, baby is sick...
Old 12-19-2008, 12:51 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Make sure the rear light connector above the footfeed pedal is in all the way. It may have worked loose. It goes through the firewall. There is also a connector at the last cross member in the rear.
LockDoc
Leon
Old 12-19-2008, 01:24 AM   #4
smoked68
smoked68's Avatar
Ok, thanks. I knew about the rear one but not @ the firewall. First things to look @ in the a.m. Any more Ideas guys?? I just need areas to search.
Old 12-19-2008, 01:47 AM   #5
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
Check the wires just behind the tag,mine was screwed up real bad there.I found one wire loose,fixed that and all was good.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 12-19-2008, 02:20 AM   #6
Infanti
www.infantimachine.com
Infanti's Avatar
I seem to remeber having a problem like this to. Check the connection at the rad support,right under the battery.Mine was corroded.
Infanti is offline   Reply With Quote
Old 12-19-2008, 02:27 AM   #7
smoked68
smoked68's Avatar
Thanks again guys, more good places to look. I'll be on it in the a.m. Going to bed now. thanks a ton for the support. Mike
Old 12-19-2008, 03:12 AM   #8
El Jay
Gone to greener pastures
Grounds.
Check all your grounds.
From battery to the engine & core support to the light housings waaaay in the back of the truck.
They can eff you up more than you would ever believe.
Just my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 12-19-2008, 06:57 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would have to say grounds too... esp since the turn signals are not on the same circuit as the tail/brake lights
Old 12-19-2008, 07:36 AM   #10
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Originally Posted by El Jay View Post
Grounds.
Just my .02.
Does anyone have a diagram showing all the grounds?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-19-2008, 09:48 AM   #11
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
There isnt many. One of the battery and then the harness assembly ...fuel pump .... then what ever accessory you have running. At least my truck doesnt have many. Id say check the fuse box.
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
Old 12-19-2008, 09:54 AM   #12
SOUTHERN917
Wrench Wench
SOUTHERN917's Avatar
I had the exact same issue, and it was the ground at the tail light housing. It "looked" OK, but when I touched it, it fell apart.
If everyone had good taste, who would buy all the FORDS?
Women join us!! BUSTED KNUCKLE BABES
"Face it girls, I'm older and have better insurance" -Fried green tomatoes
SOUTHERN917 is offline   Reply With Quote
Old 12-19-2008, 09:59 AM   #13
mekdad
mekdad's Avatar
I have had the same problem,and mine was the fuse.Dash lights and every thing in front working but nothing on the back.The fuse was blown in a spot that was hard to see by the end.
you never know what you can do until you have to undo something you have done!
mekdad is offline   Reply With Quote
Old 12-19-2008, 05:17 PM   #14
Longhorn Man
he posted in a new thread that its been figured out... the plug under the bed came unplugged
Old 12-19-2008, 07:40 PM   #15
smoked68
smoked68's Avatar
Yeah I had posted an update with a new post so folks would not waste their time. Thanks again...it was the plug at the back between bed and frame had come loose. I checked out several of the tips and worked my way to the cold hard ground, and there it was, oh what a relief. Thanks a ton and all have a merry Christmas. Mike...
