Old 12-19-2008, 01:25 AM   #1
Rack Man
What A/T Tire Can I fit on 15" x 6" Steelies?
I'm trying to figure out what tire I can fit on my stock steel wheels...Was probably just going to get a set of BFG All Terrains....their website states that the recommended tire would be a 235 series which is about 9" wide & 29" in diameter....But I also seen on a jeep forum where those guys are running up to 31" x 10.5" on a 6" wide wheel....
My truck is 1" over stock height by way of Zero Rate add-a-leafs....I would like to keep the stock wheels and stock look but I don't want a midget tire in there either...
My preference would be to run a 30" x 9.5"....do you think that would be OK on the stock 15" x 6" steelies?
Any advice would be appreciated!
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 12-19-2008, 01:58 AM   #2
Dooley
Dooley's Avatar
Re: What A/T Tire Can I fit on 15" x 6" Steelies?
Interco has a 34/9.50-15LT that fits a skinny rim. It is 33.80 tall with a 9.50 section width and 8" tread patch. Might be something you like. What gears you got?
Dooley is offline   Reply With Quote
Old 12-19-2008, 07:26 AM   #3
Blazer1970
Blazer1970's Avatar
You should be fine with 30X9.50s on the 6 inch wide wheels.
Blazer1970 is offline   Reply With Quote
Old 12-19-2008, 09:33 AM   #4
You didn`t mention what diameter wheel.A 235/75 x 16 is as tall as those other sizes shown,about 31".I think a 10" tire should be on at least a 7" rim.I run 255/85s,which BFG makes in the A/T.They are a good 33" tall.Is it width or height you mostly want?
Old 12-19-2008, 10:14 AM   #5
Jtrux
I'm a poor spectator
Jtrux's Avatar
72Levi has 31/10.50 BFG AT's on his stock rims. They're fine. Do a search and you'll see what his looks like, i've seen it in person numerous times and it looks good to me.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-19-2008, 11:29 AM   #6
Rack Man
Actually It's mentioned in the title and in the body of the post...15"
Thanks, I PM'd 72Levi to get the full scoop on his set up
