Blue 67
![]() Join Date: Apr 2004
Do I need to rebuild the my carb?
Hello:
I have an edlebrock 1406 (electric choke) which is runing very rich. I was told before on this board that I have to change the main jets. Now, it has been a while that carb spits at the first gear when truck wants to take off, also it back fires. I am at 12-15 degree advance. I don't think my engine (a 350 out of what I don't know!) is anything special,my truck just came with it. I also change my point type distributor to mallory HEI few weeks ago if that mean anything. Thanks.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
The Older Generation
Re: Do I need to rebuild the my carb?
I don't know a lot about carbs or what kind of adjustments the Edelbrock has so I can't help there but it seems to me that 12-15º advance is a little steep for a stock 350ci small block. I would think 8-10º would be a better number and make sure it is set with the vacuum advance hose off and plugged. Did you re-gap your plugs when you put the HEI in? LockDoc .
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-19-2008 at 10:07 PM. |
Blue 67
Re: Do I need to rebuild my carb?
Why the carb pups though? Is it just because the advance issue or it could be accelator pump assembly in the carb.
Have you "played" with your timing any? Adjust, drive, adjust, drive...? Vac. advance?
A quick check of the accel. pump. With the engine off look down the throat of the carb & move the throttle from the idle position. There should be 2 squirts of gas go in the throats. If not or it just dribbles, the accel. pump is bad. Take out a spark plug or 2 after being driven. If there is black carbon on the porcelan it is probably running rich. With the engine idling slowly turn the idle jets, one at a time, in till the engine starts to slow down. Then back it out about 1/2 turn till it runs the smoothest.
