12-20-2008, 12:17 AM | #1 |
how to wire asco 2 way valve to air ride e2 controller
just like the title says i'm clueless on how to wire the asco valve series 8238 2 way internal valve the thing is the valve has a three connector's, know the controller i'm going to be running is the air ride e2 controller air ride said it will work with any 4 way valve set up so i'm running 4 3/8 port asco valves but the wire harness that comes with the controller has two wire's per valve and the asco valve has three so if anybody could help me with this problem i would appreciate
12-20-2008, 04:58 PM | #2 |
Re: how to wire asco 2 way valve to air ride e2 controller
anybody
12-21-2008, 05:49 PM | #3 |
On would be a ground the other two are your inputs. Pics? I am not familiar with that manifold. The ones we use are wired separately, sounds like you may have a spool valve.
12-22-2008, 10:35 PM | #4 |
you only use 2 of the 3 prongs
12-22-2008, 11:58 PM | #5 |
how do you determine which ones to use
12-23-2008, 12:41 AM | #6 |
Sorry if your taliking about the regular brass solenoid valves you use the 2 larger tabs, the small one one bottom is not used. They are not polarity specific.
12-23-2008, 10:13 PM | #7 |
thanks
12-24-2008, 10:19 AM | #8 |
Jon@AirRideTech
shoot me some pics of the connections on the valves jon@ridetech.com
Selling The best Damn Air Suspension www.ridetech.com jon@ridetech.com (812) 482-2932 |
