Old 12-20-2008, 10:58 AM   #1
Boog
laying low
Boog's Avatar
1/2 & 3/4 diffs
While looking over some of these pics I got to wondering just what are the differences between the 1/2 ton and 3/4 ton trucks.
Frames
Springs
Brakes
and so forth.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-20-2008, 11:10 AM   #2
Re: 1/2 & 3/4 diffs
Same frame with heavier springs,brakes,and wheel bearings.The rear axles are bigger and full-floating.
Old 12-20-2008, 12:20 PM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
Re: 1/2 & 3/4 diffs
Also wheels,lower ball joints,control arms (I think),plus 3/4 longhorns = stronger frame.
I think the front springs are the same.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 12-20-2008, 12:42 PM   #4
MrGoodpliers
MrGoodpliers's Avatar
Re: 1/2 & 3/4 diffs
Aside from all of the obvious suspension stuff, the rear cab mounts on the 3/4 are thicker, thus placing the brackets lower on the frame.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 12-20-2008, 05:10 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 1/2 & 3/4 diffs
Frames are somewhat different.
Old 12-20-2008, 09:06 PM   #6
Boog
laying low
Boog's Avatar
Re: 1/2 & 3/4 diffs
The 3/4 should have beefier spindles, tierod linkage and sway bars wouldn't it? And I believe the brake shoes are about 1/2" wider than standard 1/2 ton shoes.
The 3/4 is actually better suited for towing and hauling. I just don't know if I'd like driving one everyday, ridewise.
I have seen some owners buy the 3/4 then swap in the 1/2 ton suspension for wheel choices and drop kits but that just makes them 1/2 tons then.
Are the custom wheel choices pretty slim for the 8 lug trucks?
Boog
primer is finer
Old 12-20-2008, 09:13 PM   #7
Camper Power
Camper Power's Avatar
Re: 1/2 & 3/4 diffs
i believe the 3/4 have befier springs and brakes all around, heavier control arms, and bigger axels. for the rims you cant really get street like rims, but there are some pretty nice off road rims that i wouldnt hesitate to buy.
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 12-20-2008, 11:55 PM   #8
jorgensensc
jorgensensc's Avatar
Re: 1/2 & 3/4 diffs
THe wheel choice for vintage looking 8 lugs is slim. Unless you are going for slots, vectors, stock steel wheels, wagon wheels, or centerlines. Everything else is made for the newer 8 lug vehicles, so they are a little Blingy. They don't have the same vintage feel that Torque thrusts or Hopsters do. We have a 3/4 ton '72 Burb that will be my wifes daily driver soon. It took us awhile to find new wheels that we felt kinda felt right. they were Dick Cepeks. They are close to what we want, but still not exactly right. I am installing air bags to elp with the suspension harshness issues. It will be well suited for towing though.
Don't forget the disc brakes up front are bigger also.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
