Old 12-20-2008, 11:14 AM   #1
Larry S
Larry S's Avatar
69 cab sandblasting
What is a reasonable rate to have a 69 cab sandblasted and primed with epoxy? I the cab gutted and all undercoating scraped off. Thanks
Larry S is offline   Reply With Quote
Old 12-20-2008, 12:06 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 69 cab sandblasting
Probably not much unless the blaster really knows what they are doing.Sandblasting really builds heat and can warp panels.If you have it blasted you really want to use a media.It will strip paint but may not get all the rust.IDK on the priming.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-20-2008, 12:14 PM   #3
Chevymann1968
Chevymann1968's Avatar
Well i had the same question so i called the local media blaster and the only thing he could say was "bring it to me so i can see it" I guess to see how much work it would take??
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Chevymann1968 is offline   Reply With Quote
Old 12-20-2008, 12:17 PM   #4
72armyswbtruck
72armyswbtruck's Avatar
I have had a few quotes on media blasting (media being better on the metal then sand).
Between $125 to $300.
I got an entire cab and chasis media blasted for $250 the last time that I had it done.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-20-2008, 12:49 PM   #5
Scottshotrods
69 cab blasted in ca, $400.00
cab being sealed runs $300.00.
Make sure the blaster knows what
he is doing they can warp the metal
real bad with to much pressure.
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 12-20-2008, 02:07 PM   #6
dfosh
I had a 51 chey done about three years ago and i had all the parts done except frame and bed and it was 700 dollars . I had stripped it down to the orrignal primer . Yes they need to know what they are doing ,check work they have done for others. The 70 and 68 trucks i have now i am going to h ave parts of them done that they cant warp.
dfosh is offline   Reply With Quote
Old 12-20-2008, 06:23 PM   #7
haysonj
haysonj's Avatar
Justin
I did mine myself for $30 in sand used my company compressor and sand pot. you have to work about 4 feet back and dont stay in one area very long. Mine came out great with no warpage. I used a 30 grit sand and sprayed with sanding primer and kept it inside til it went to the paint shop. had to replace both rockers after blasting due to rust being exposed.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
