Old 12-20-2008, 07:39 PM   #1
spudz
spudz's Avatar
I6 to V8 swap questions...
I am fixing to pull my blown 250 from my 77 shortbed work truck and replace it with a 350. I want to keep the original 3spd manual trans. Can I use the flywheel from the 250 on the 350? Or do I need to get a v8 flywheel.. The flywheel, clutch and pressure plate isnt that old so I was just going to use it if I can. thanks! also I am guessing the rearend has some pretty low gears because of the six, what gear goes good with a 350, 3 on the tree??? Dont really care about MPG, just want to be able to pull a small trailer and go 70mph if need be.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-21-2008, 10:07 PM   #2
spudz
spudz's Avatar
Re: I6 to V8 swap questions...
ttt
Old 12-22-2008, 10:06 AM   #3
Tony@AirRideTech
Junior Member
I am not positive about the 250 but I have done some 235 to V-8 swaps and they required new bell housing, clutch, flywheel , starter, and motor mounts.
Tony@AirRideTech is offline   Reply With Quote
Old 12-22-2008, 11:08 AM   #4
manimal
manimal's Avatar
drops right in. On the motor mount it will be stamped "6" and "8",just move the clam shell to the right position and drop in the engine. You can use the flywheel,clutch and all. good luck.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 12-22-2008, 05:24 PM   #5
spudz
spudz's Avatar
THANKS! thanks what I needed to know!
Old 12-22-2008, 09:55 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Here ya go: http://www.persh.org/Pickup/perches.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
