12-20-2008, 07:46 PM | #1 |
383 stroker question....
My buddy says that a 383 stroker is built from a 350 block w/400 (or larger) cam. Is there any truth to this or is he full it?
I don't know much about the mechanics side of things, so I'll have to depend on the brotherhood within these pages. So what's the skinny on this? Thanks, Greg |
12-20-2008, 07:52 PM | #2 |
Re: 383 stroker question....
Cam or crank A 383 it a 350 block and 400 crank!!!
1968 GMC Rebuilding Stage 2001 Camaro SS SOLD |
12-20-2008, 08:05 PM | #3 | |
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
12-20-2008, 08:08 PM | #4 |
I concur! the legendary stroker is more complicated than most think, you need a bore of 4.030" (350 bored .030 over) and a stroke of 3.75" (400 rods and crankshaft), although most skip the .030 over pistons and simply call there 376 a 383...
12-20-2008, 08:13 PM | #5 |
I figured that there would be more to it, but that's just the basics of our conversation.
I am pondering the thought on putting a 383 stroker in my '72. I guess you could say that I just haven't grown up yet. I still like having my head pulled back against the rear glass when you punch the pedal to the floor. I just purchased another '72 and the PO said the engine threw a rod. I made the "I wish I had a 383 stroker" comment to my buddy, and he said, "Well, you've got the start of one sitting right here in front of you w/the '72 you just bought. Tear it down and do it!" Greg |
12-20-2008, 08:58 PM | #6 |
I was going to build a 383 stroker for my bucket then i decided against it and went with a small block 400....I feel that it was alot easier to do what i did than to have built the stroker just my opinion...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-20-2008, 09:46 PM | #7 |
I have a stroker going into my 67 and all I can tell ya is that it goes from 2000 rpm to 8000 rpm in about two seconds compared to a stock 350 or 400 that has some lag time.
12-20-2008, 10:44 PM | #8 | |
there is zero lag on mine!!!!
12-20-2008, 11:22 PM | #9 |
Do a stroker! look up some of the articles super chevy, chevy hi pro, and car craft have done on cheap 383 builds, they seem to work out well and make nice power
12-21-2008, 12:29 AM | #10 |
Can a 400 be made into a 383 with a 350 crank ? or does it not work that way ?
72 C20 Longbed 05 1500 Z71 |
12-21-2008, 01:32 AM | #11 |
A 400 with a 350 crank .030 over is a 377. And my 406"s rev faster and make more power than any other small block I've ever had.My .02
12-21-2008, 04:26 AM | #12 |
BigSnook I just bought a 400 2 bolt for a 406 or 421 build for my '72 K10 (4x4). I was using an article out of Chevy High Performance as reference for the build except with aluminum heads so my CR can be somewhere between 10.0-10.5 : 1. I have never built a 400 before any tips that come from your experience? Thanks.
12-21-2008, 08:00 AM | #13 |
I had a machine shop build my stock 350 into a 383..engine was bored,then they used a stroker kit from summit..runs great..JZ
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
12-21-2008, 08:57 AM | #14 |
I am a Referee of life.
383 builds more torque
377 is for revs 400 are good but they can be stroked also.Any of the members that don't have much engine knowledge can read engine masters,Car Craft or other magazines and get more theory to go with tearing and engine down for more lab style work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-21-2008, 10:41 AM | #15 |
72 HULK, I have a few tips that might help you out. I always Zero deck and square the block,use torque plates and torque the main caps to specs when boring the block. I also block off the steam holes in the block and have the plugs cut when they deck it. I use the thermal coatings on the tops of the pistons and combustion chambers and on the face of the valves. I believe in, and use a crank scraper,windage tray,and lifter valley baffle,and use a screeen kit in every motor.The screen kit will keep things from going to the bottom of the motor if a roller rocker goes away.I also use ARP head and main studs on my motors. This provides better fastening and truer torque readings. Use a very good cooling system, though I've never had any overheating problems with my 406's. I know some of the things I mentioned are a little pricey, but I think it is money well spent in the long run. And that's my .02
12-21-2008, 11:01 AM | #16 |
So, how are the stroker engines on the hwy? Say for like a road trip that may be a couple of hours long? Is it wise to build an engine for power/torque and still expect it to make long runs?
Greg |
12-21-2008, 01:56 PM | #17 |
the big thing with a stroker and the hiway is to gear it well.You can actually run most strokers at a lower rpm with lower(numerically 4.11 being higher than 3.08) because they have enough power to pull at lower rpms.Cam selection will also play a role since it helps determine the rpm range the engine is happiest in.
There is so much to learn about engines to be able to put together a combination that will do what it was designed to that we could fill the whole BB up and still miss a lot.If you are building an engine and the crank needs to be turned than it is usually money well spent to build with a stroker kit since a couple hundred dollar will usually net you increased torque and performance.
12-21-2008, 06:13 PM | #18 |
I would just drop in an LS1 or newer v-8, you don't need fuel injection or a computer if you don't want that.
