Old 12-21-2008, 12:45 AM   #1
BIGBLU 72
BIGBLU 72's Avatar
Factory Tach Cluster
Im changing the cluster in my 72 jimmy from the basic gauge cluster to cluster with a factory tach. i was wondering first if i have to change the plug-in from the wiring harness to match the new cluster? and also how to hook up the vaccum gauge
thanks DAN
BIGBLU 72 is offline   Reply With Quote
Old 12-21-2008, 01:09 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Factory Tach Cluster
There is a separate wire harness for the tach. You can get it from just about any vendor. I don't know about the vacuum.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-21-2008, 01:22 AM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
Or you can just buy some wire and spade connectors and do it yourself, up to you.
As far as vacuum, I guess you could tie it into your carb or intake.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-22-2008, 01:07 AM   #4
badpeanut
Not a bad nut after all..
badpeanut's Avatar
thanks DAN
Here is some good info: http://67-72chevytrucks.com/vboard/s...d.php?t=313785
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 12-22-2008, 01:15 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
If your dash is currently the 3 guage set-up, then there is some re--wiring/ re-pinning of the wiring harness. IF you have the 5 guage cluster currently then it is mainly a plug and play. Except you will need the tach wiring harness which is around $25.00 from most of the vendors on this site.
Do a search under the Tech area and you will find a write up on how to do it correctly and a wiring diagram.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
