Old 12-21-2008, 10:43 AM   #1
sourkraut
sourkraut's Avatar
Block Hugger Header Suggestion
I am using a set of stainless steel block hugger headers. I love the look of them but my engine is using the front mounts. With the engine in the front mounts it dumped the header right down on the crossmember. I came up up with a very simple solution to correct the problem. If you cut the collector flange parallel with the factory weld and turned the lower part of the flange 90deg to get the out put heading towards the rear of the truck and on a perfect angle to miss the crossmember. I figured I would post this if there was anyone else who wanted to use this style header but was having the same problem.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 05-01-2009, 07:22 PM   #2
dakman
Re: Block Hugger Hedder Suggestion
nice, who makes those?
dakman is offline   Reply With Quote
Old 05-02-2009, 02:43 PM   #3
sourkraut
sourkraut's Avatar
I had bought them off of ebay. stainless steel and they were $125 from skip white. here is a link to a set.http://cgi.ebay.com/ebaymotors/SBC-C...1%7C240%3A1318
Old 05-02-2009, 05:10 PM   #4
dakman
thanks!!
Old 05-02-2009, 06:28 PM   #5
Why buy a ford?
This is awesome because i am looking at these exact headers right now but my dad is trying to talk me out of them because of this reason. I don't exactly understand what you did here tho?
Why buy a ford? is offline   Reply With Quote
Old 05-02-2009, 06:44 PM   #6
Why buy a ford?
Do you have to have a specail welder to weld stainless steel?
Old 05-02-2009, 07:35 PM   #7
sourkraut
sourkraut's Avatar
what I did was cut the downspout and turned it 45 deg. instead of the spout shout down and straight it angles it back and toward the back of the cross member. it works out great!
I have a tig welder and that is what I had used to weld them with. you could use a mig setup to weld stainless. if you would be interested you could send me the header and i could weld it for you. i would only ask that you would cover my electric and gas to weld it. i would like $10-15 to cover it. if interested let me know. i had put a thread up asking if people would be interested in an online welding service. I will add link so you can see some welds if you are concerned. also if interested I will include link to a guy that I bought all of my SS exhaust tubing from. great guy with great prices, that can't be beat on SS tubing.
http://67-72chevytrucks.com/vboard/s...d.php?t=332868
this is the kit I used for my truck: http://cgi.ebay.com/ebaymotors/Exhau...Q5fAccessories
Old 05-02-2009, 07:41 PM   #8
sourkraut
sourkraut's Avatar
why buy a ford, here is a pic of the left header and right one and how it works out. the right side is not the best and can post a better one if needed.
Old 05-02-2009, 10:13 PM   #9
RCbowtie69
RCbowtie69's Avatar
cool
RCbowtie69 is offline   Reply With Quote
Old 05-03-2009, 03:22 PM   #10
Why buy a ford?
Where are you located exactly? i would be interested if the shipping there and back wont be too rediculous.
Old 05-03-2009, 06:31 PM   #11
sourkraut
sourkraut's Avatar
central, pa
Old 06-03-2009, 06:50 PM   #12
dakman
well they are on their way, didn't see it in the listing but are they 2 1/2 or 3 inch after the collector?
Old 06-04-2009, 12:00 PM   #13
sourkraut
sourkraut's Avatar
they are 2.5"
Old 06-04-2009, 01:09 PM   #14
dakman
perfect! Thanks again for pointing me towards these, I won't need any mods though because my 400 is in the rear mount location, they should clear the crossmember.
Old 06-05-2009, 03:08 PM   #15
sourkraut
sourkraut's Avatar
Cool! Good luck!
Old 06-17-2009, 08:11 PM   #16
dakman
crap.. the pipe attached to the flange is only 2 inch diameter.. I was afraid of that... needed a 2 1/2. Not sure why they don't put that in the ad.
Old 06-17-2009, 08:31 PM   #17
sourkraut
sourkraut's Avatar
you are correct! I dont know either! but I had just cut mine and armydiesel13's off and welded the 2.5" to the flange and it works fine. let me know if you need help or anything.
Old 07-21-2009, 09:22 AM   #18
dakman
well now I'm confused, I tried installing them and they are hard up aginst the block just below the center cylinders and the flange at the collector is hard aginst the oil pan lip??? I called skipwhite and they said they've never seen this and that there is only one type of SS block hugger header they sell. I definately dont have the block clearance that you do in those pics. I noticed the title in your ad had YK-1 one at the end and mine didnt but they say that wouldn't matter.
Old 07-21-2009, 03:48 PM   #19
sourkraut
sourkraut's Avatar
I am sorry you are having troubles. Did skipwhite offer to make it better/rectify the situation? If there is anything I can do to help let me know.
Jon
Old 07-21-2009, 04:01 PM   #20
dakman
Re: Block Hugger Header Suggestion
no... his tech guy basically gave me the oh well attitude. I checked my heads but there are no signs they've been machined, they look normal compared to other sbc heads, pulled the covers off as well and found out they were the stock 333882 heads that match the 76 400 motor and I doubt they've ever been off. Guess I got a bad set of headers. I noticed yours have a flat profile on the flange where the ones he offers like mine are milled out between where the runners come out of the flange. They might have changed the tooling or something that screwed up the angle. I'll post some pics here in a second. Ignore the dirty motor it runs like a champ!
Old 07-21-2009, 04:53 PM   #21
dakman
pics.. at least they clear the mounts! There is contact with the block where both outer tubes come down under the head and into the collector. Both sides.
