fusable link again
My 70 does not have the link between battery and junction block. In some of the wiring diagrams it looks like the wire from the bat to block is 18 gage and some look like it says 16 gage. According to this post below I found it is 10 gage. So would I be correct that the wire that comes on the bat cable is 10 gage and the link I would buy should be 16 gage? Does the link connect directly to the block or is there another wire between them?
Quote from the 1971 Chevroklet Truck Chassis Service Manual. " Fusible links in the Chevrolet wiring are four gauge sizes smaller than the cable it is designed to protect". The engine compartment wiring is illustrated as a 10 gauge red wire coming from ythe battery + to a junction block. A fusible link of 16 gauge wire attaches to the junction block and red 12 guage wire then to the various circuits. If you desire to construct your own link; use a short piece ( 1" or so) of solid ( not stranded!) wire attached to the junction. Slide a piece of heat shrink tubing down the 12 gauge wire and then solder the 16 gauge to the 12 guage. When solder joint has cooled; slide the heat shrink tubeing over the juntion of the 16 & 12 guage wires. .........
70 CST Bunch of old Camaros ![]() |
![]() Join Date: Oct 2008
Re: fusable link again
Yes battery wire is 10 gage and you need a 16 gage fusible link. No there is no wire between them. The other wire you might see in pic is for optional equipment. I would have to look closer but I think it’s for the amp meter.
As you can see in pic attached the 10 gage goes between battery and junc block. The 16 gage fusible link goes between the junc block and main feed wire 12 gage RED Hope this helps
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
The wireing diagram on this site shows the link between the bat wire and the junction block. What diagram did you post and does it make any difference which way?
Old Skool Club
![]() Join Date: Jun 2001
Makes sense to have it between the battery and the junction block. If my truck had been equipped with one, it would have saved me some $$ and some burned fingers from pulling the glowing 10-ga. wire in two, to save the truck from burning up.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
The pic is from a 1972 Chevrolet Truck wiring diagrams for complete chassis.
The primary purpose for the fusible link is to protect the wires in the total truck electrical system from burning up/melting and prevent the battery from receiving a high amp charge from a faulty alternator or regulator. The advantage to wiring per the pic is you can add a high amp circuit to the truck like fog lights and others with out pulling more amps from the stock circuit design than it’s made for. Of course you will have to protect the added circuit with a fuse to prevent meltdown. If no shorts or equipment malfunctions would happen you would not need any fusible link or fuses but that’s not how things are so I highly recommend running a fusible link in ether location the protection will still be there.
HERE.......Somewhere
I still cant find mine at all I looked all over for a fussible link
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 ![]() ![]() Classics make it possible! |
#7 | |
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 Last edited by Bruce88; 12-22-2008 at 01:17 AM. |
My 72 has something on the black wire that looks like a fusible link. maybe it's just a butt end connector. No Fusible Link needs to be on the Black wire correct?
![]() Join Date: May 2014
You may be talking about the inline fuse for the BATT Gauge. There's one located behind each headlight.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
I already looked for those and didn't see any on my 72. I'm actually referring to the black 14ga wire coming off the junction block. any idea where it goes?
This also might help.
Sure Did. Thanks,
Here are the links. http://67-72chevytrucks.com/gallery/...&size=big&cat= http://67-72chevytrucks.com/gallery/...&size=big&cat= Last edited by E.TexasTwister; 08-17-2016 at 01:29 PM. |
#13 |
Could have been replaced with a Non fuesable type wire. My 68 has a Factory fuse that can be replaced (4A) SFE glass fuse. FACTORY BABY!!
#14 |
here is some more ideas
http://67-72chevytrucks.com/vboard/s...d.php?t=433539 |
