Old 12-21-2008, 03:06 PM   #1
1966gmc
Why does it taste purple?
1966gmc's Avatar
Shoulder belt question
Has anyone put shoulder belts in a 64-66 and what kind did you use? How did you attach them at the top? I have so many questions on this because mine are not equipped with any type of belt and I would feel safer with a shoulder belt set up. Thanks in advance guys
1966gmc is offline   Reply With Quote
Old 12-21-2008, 04:33 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Shoulder belt question
I installed a three-point belt system in my '63. I got my kit from Classic, IIRC. I mounted the top part of the shoulder harness just above the seat on the B-pillar.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-21-2008, 04:37 PM   #3
502tripower
502tripower's Avatar
I used the 98 Silverado belts to match my seat. I put the bosses in when I did the big window conversion. You can see the hole where the shoulder harness mounts in the the pic. The recoil unit mounts just behind the door pillar. The other option you have is to purchase a newer Silverado seat that has the belts built into the seat.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 12-21-2008, 05:36 PM   #4
Oregoon
Roadside Rebuilder
Oregoon's Avatar
I'm gonna use floor-mounted shoulder harnesses. A bit of a pain, but I can securely mount them, and they're about as safe as it gets.
Plus, you get the OG racecar look.
Oregoon is offline   Reply With Quote
Old 12-21-2008, 05:43 PM   #5
1966gmc
1966gmc's Avatar
Any pics or links?
Thanks for the advice guys
Old 12-21-2008, 07:52 PM   #6
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Well, on the budget side, there's these: http://www.streetbeatcustoms.com/tuc800-sy.html
Not bad, but a bit too tuner-car for my tastes.
Then there's these for a few bucks more: http://wescoperformance.stores.yahoo.net/am4point.html
And finally, there's these NHRA type belts: http://www.jegs.com/p/G-FORCE/758245/10002/-1
I'll probably use the wescos, black with the chrome lift-levers, since I'm looking for something safe, low-key, and unobtrusive.
Plus, with a suburban, I've got to buy quite a few...
Old 12-21-2008, 08:25 PM   #7
1966gmc
1966gmc's Avatar
I thank you sir
