Old 12-21-2008, 03:38 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Porterbilt Dropmember?
I am buying a chassis without a front crossmember. If I get a dropmember can I so a static drop instead of bagging it? Will it make the static drop lower with the dropmember than without it?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-21-2008, 03:48 PM   #2
royo
royo's Avatar
Re: Porterbilt Dropmember?
Say what . you want to use coil springs on a drop member.
nickle and dime
royo is offline   Reply With Quote
Old 12-21-2008, 04:28 PM   #3
SCOTI
SCOTI's Avatar
Why static drop? If you're trying to budget the 'swap', you could go w/schrader filled bags to start & then add the air management as funds allow.
If it's not a budget thing, I know Porter looked into making a coil-spring version of The Dropmember but the complications of the build requirements deemed it one-off/spec request vs. something that the avg. Joe might want. It can prob be done, but the issue will be the placement of the coil in the lower a-arm vs where the upper mount is (remember the track width is narrowed so the spring C/L is moved farther out on the lower a-arm vs. where the OE spring C/L was).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-21-2008, 04:39 PM   #4
scotts62
One day...
scotts62's Avatar
If your not wanting to bag it just just a stock crossmember from a 73-87 put some drop spindles on it and call it good.
Scott
93 crew cab build
Project 62
Old 12-21-2008, 05:13 PM   #5
thirdstreettito
Resident of Here
Ohhh. Will a 73-87 give me a bit more drop than just spindles/springs? Btw it is a 68 LWB 1/2 ton chassis. All help appreciated.
~Bradley~
Miss having a truck
Old 12-21-2008, 05:36 PM   #6
SCOTI
SCOTI's Avatar
No. You won't gain any 'drop' vs. the correct 67-72 c.member. What is your goal?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2008, 05:39 PM   #7
royo
royo's Avatar
Hay if you need a stock crossmember i have one its free
nickle and dime
Old 12-21-2008, 06:15 PM   #8
thirdstreettito
Resident of Here
My goal is about a 4/6-5/7 drop. Somewhere in that range.
~Bradley~
Miss having a truck
Old 12-21-2008, 06:43 PM   #9
SCOTI
SCOTI's Avatar
4/6 drop is easily obtained using drop spindles + shorter coils (either cut stockers of aftermarket dropped springs). 4/6 drops are also not so 'radical' that you have to constantly worry about the lower a-arms hitting the road.
The 5/7 drop is just more spring drop vs. the 4/6. The 5/7 drop does get the a-arms close enough that there's a 'pucker-factor' on some roads.
This is where the Porterbuilt Dropmember (or most aftermarket front c.members) offer increased value as they allow for drop while keeping the a-arms farther away from the roads surface (some more than others).
Coil or leaf rear suspension?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2008, 08:41 PM   #10
thirdstreettito
Resident of Here
I have rear coils. I know all about drops and such. I was just wondering if I "had" to bag my truck to add the PB Dropmember. I think I will go with 4/6 and maybe some helper bags for the heavy loads. Eventually I want to do a Kelderman system.
~Bradley~
Miss having a truck
Old 12-21-2008, 08:49 PM   #11
Scottshotrods
if you are not on a budget and know how to do some welding.Look at the scotts
superslam ifs for your frame.We also have the
scotts standard ifs for your
truck,this comes with alden
coil-overs.
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 12-21-2008, 10:44 PM   #12
thirdstreettito
Resident of Here
coil-overs.
Justin
Thanks. Can the IFS handle weight? Like if I got a yard of dirt in the back? It would only be an extra couple hundred pounds on the IFS.
~Bradley~
Miss having a truck
Old 12-21-2008, 10:51 PM   #13
Scottshotrods
Thanks. Can the IFS handle weight? Like if I hot a yard of dirt in the back? It would only be an extra couple hundred pounds on the IFS.
we have built our ifs systems and have installed them on
chevy crew cab duallies
48 chevy cab over car haulers
one ton 58 chevy trucks
to answer your questions yes they can we build our ifs
per vechile applications and what purpose you are going
to be using it for.
Justin
