12-21-2008, 09:57 PM | #1 |
Moderator
Blazer fuel filler measurement
I was wondering what the diameter of the fuel filler hole is on the left rear bedside of Blazers? Here is a pic showing where the filler neck sticks out. I am going to use a Blazer filler for my relocated fuel tank, and need to know the measurement of this hole. I am going to add a factory gasket, and want it to fit properly. Thanks!
12-22-2008, 03:32 PM | #2 |
Moderator
Re: Blazer fuel filler measurement
bump...anyone? Mods: If you think this belongs in the Jimmy/Blazer forum, please move it. I figured this forum got more exposure. Thank you.
12-22-2008, 04:31 PM | #3 |
Out of the carpool lane.
What I did was take the Blazer filler tube and relocate it to the inside of the bed. I then took the Blazer filler tube cover and placed it the same as original but I had to modify it slightly to match the angle of the filler opening plate. Here's a pic of what it looked like:
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
12-22-2008, 04:55 PM | #4 |
Moderator
That is kinda sorts what I am doing, but I need the hole diameter to make the cut and add a factory gasket
12-22-2008, 05:21 PM | #5 |
Ok, I just thought I'd offer an alternative to punching out the side of a bed. Sorry, I can't help you with the hole dia.
12-22-2008, 10:37 PM | #6 |
Moderator
Does anyone know if the filler neck gasket is the same for Blazers as it is for the 67-70 trucks?
12-22-2008, 11:23 PM | #7 |
I have a Blazer bedside in the parts pile, I will go out tomorrow morning and see what I can find. I don't think the gasket is the same but i'm not sure.
12-23-2008, 11:25 PM | #8 |
That bedside still has a filler in it. I will try to get it apart and get you an answer in the next couple of days. I cut a hole in one and memory tells me it was 3" on the outside wall and 2.5" on the inside wall. I will verify if no one else chimes in before.
12-24-2008, 02:24 AM | #9 |
Moderator
Thanks Brandon. I did some research and found that it is 3" in diameter. I am going to make a template to trace it out. That is a really nice Jimmy you have! I can't wait to see it in person.
