12-22-2008, 12:12 AM | #1 |
Another alignment question
What are you guys with bags using for alignment on the uppers ? Are you just running a shi load of shims or some sort of larger spacer? Pics would help...thanks....
12-22-2008, 05:34 PM | #2 |
Re: Another alignment question
echo
12-22-2008, 11:54 PM | #3 |
OMG! you read my mind! (that's why i love this forum) I noticed a butt load of shims when pulling my upper control arms. Luckly, I kept em and and used them for the new control arms I pilfered. As I was putting things together, that thought crossed my mind. Very curious (like George, the Monkey) on this one
12-23-2008, 01:47 AM | #4 | |
yep a hole bunch o' dem
1987 Gmc sierra 1962 Apache 10 |
12-23-2008, 04:51 AM | #5 |
VA72C10
ttt
Looking for a 67-72 swb or blazer project in or around VA. |
12-23-2008, 10:06 AM | #6 |
Surely there is some sorta sleeve that you can put over the bolts that will act like a spacer....hmm....but i wonder if it would be strong enough?! Time to go to the home depot hardware section....
12-23-2008, 11:06 AM | #7 |
Junior Member
You can use a sleeve or steel bushing if you want... all you are doing is shimming the arms in to gain alignment. One of the reasons they engineered that front end with that many shims is because that is back in the days when automakers were engineering their vehicles to last for more then 4-6 yrs (average payment terms and extended warranties) and they were allowing you to be able to compensate for crossmember sag. They also did it because body / chassis tolerances in those days were measured with a ruler
12-26-2008, 02:22 AM | #8 |
100% gearhead
I used 1" longer A-arms and camber never gets too outta whack throughout the travel. I use no shims.
